Ladder bar setup, where to put the wieght? #328956
05/26/09 10:36 AM
05/26/09 10:36 AM
Scatchamatoon
Saskabusa Offline OP
Scatchamatoon
I recently installed a set of CE ladder bars in my car. Last weekend I made my first passes with this setup. I got the best et, mph and 60' ever so I'm pretty happy. After talking to some guys at the track and doing a bit of research I realized my setup of the bars is far from perfect or good. I got the coilovers and springs adjusted to the proper hieght they had been setup with too much preload in the springs. Then I borrowed a set of car scales and have my car setup on them. So now I have some numbers from them but I'm not sure exactly what to do with this info.
FL:1145# 31.5% FR: 909# 25.1%
RL: 762# 21% RR: 808# 23.3%
Total:3618
These wieghts are the car in race trim with driver in the seat and I'm 200#.
So what I'm asking is what kind of distribution of wieght am I looking for. Completely even on all four tires?
The car is a 1967 Dodge Charger 440 10.3-1 E-heads 4500 converter 4.10 with a 30x9 tire coilover springs are the 150#
Best run was a 11.158 @ 119.953mph 1.539 60'
1974 Roadrunner
1967 Charger
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328957
05/26/09 10:54 AM
05/26/09 10:54 AM
your car is typical of a lot of Mopar with either stock or race rear suspension. Most of the cars have less weight on the RR than the LR so yours is good did you adjust the LF torsion bar to move weight onto the RR? If not you can and it may move some weight over onto the RF at the same time, maybe not If the car goes straight now as it is I would probally leave it alone
Re: Ladder bar setup, where to put the wieght? [Re: Cab_Burge] #328958
05/26/09 11:06 AM
05/26/09 11:06 AM
Scatchamatoon
Scatchamatoon
The LF torsion bar is cranked up a bit more than the right. This is just a happy accident though. Car went slightly left but not very much.
So you figure this distribution is in the right ballpark?
I plan to lift the car up about 1/2" on the coilover brackets. When I properly adjusted the springs it came down a little.
I have the extra flimsy drag T-bars in the car so they both have a lot of preload on them to achive the ride hieght. This seemed to work good on the old SS springs but is it nesasary for ladder bars?
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328959
05/26/09 11:34 AM
05/26/09 11:34 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
What about the bars out of the "black monster"?(318-383)
Re: Ladder bar setup, where to put the wieght? [Re: RemCharger] #328960
05/26/09 01:29 PM
05/26/09 01:29 PM
Scatchamatoon
Scatchamatoon
Can't take those I need them to complete the restoration on it.
I would intstall /6 bars first and drop the amount of preload a little bit before I tried the V8 bar.
1974 Roadrunner
1967 Charger
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328961
05/27/09 01:11 AM
05/27/09 01:11 AM
Saskatchewan, Canada
barracudabob Offline
What diameter are the drag bars?
Re: Ladder bar setup, where to put the wieght? [Re: barracudabob] #328962
05/27/09 05:27 PM
05/27/09 05:27 PM
Scatchamatoon
Scatchamatoon
Not exactly sure they are smaller than /6 bars.
1974 Roadrunner
1967 Charger
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328963
05/27/09 05:46 PM
05/27/09 05:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your in the ball park.... lower the left T-bar a
little to take some of the pre-load out, that will
keep the car from going left
Re: Ladder bar setup, where to put the wieght? [Re: MR_P_BODY] #328964
05/27/09 06:35 PM
05/27/09 06:35 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You should see the car though looks like the front bumpers rubbing the ground...
Re: Ladder bar setup, where to put the wieght? [Re: RemCharger] #328965
05/27/09 07:25 PM
05/27/09 07:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well you can go the other way and turn up the right
T-bar to help reduce the RR pre-load... or just take
some pre-load out with the RR ladder bar
Re: Ladder bar setup, where to put the wieght? [Re: MR_P_BODY] #328966
05/27/09 10:52 PM
05/27/09 10:52 PM
Scatchamatoon
Scatchamatoon
the front end hieght is with in a 1/4" at rest side to side. Passenger side is a 1/4" higher. I'm going to lift the drivers side another 1/4", then check the ladders bars for preload. I never did check them so that might be the wander at launch, which was very minor.
1974 Roadrunner
1967 Charger
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328967
05/31/09 10:20 PM
05/31/09 10:20 PM
Scatchamatoon
Scatchamatoon
1974 Roadrunner
1967 Charger
Re: Ladder bar setup, where to put the wieght? [Re: Saskabusa] #328968
05/31/09 11:31 PM
05/31/09 11:31 PM
All of the launches and the rest of the runs look good to me
