How to id 66-69 b body disc brake spindles #328893
05/26/09 08:28 AM
05/26/09 08:28 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
how do you id disc brake spindles for a 69 b body I am starting to question if I have the correct parts the caliper hits the rotor when bolted up I know the calipers are correct but not sure of the spindles or rotors also if anyone knows what the diam of the rotor hat area is for the correct rotors this has turned into quite the mess thanks for any help will the bendix caliper bolt to the newer style spindle??
Re: How to id 66-69 b body disc brake spindles [Re: biff426] #328894
05/26/09 11:07 PM
05/26/09 11:07 PM
My repro one piece rotor had clearance issues with the caliper also. Had to have the rotor machined a little. Wasn't much but now it clears it.
Re: How to id 66-69 b body disc brake spindles [Re: biff426] #328895
05/27/09 11:41 AM
05/27/09 11:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What rotor do you have and NO the original caliper will not bolt directly to a newer spindle , at least I never tried it or heard of anyone trying it ... I do have 73 up A body spindles and my calipers in the basement though
Re: How to id 66-69 b body disc brake spindles [Re: JohnRR] #328896
05/27/09 12:32 PM
05/27/09 12:32 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I have 1 piece rotors that came with the car the caliper hits the part of the rotor between the lug studs and the rotor face someone ground the old calipers to fit just noticed that is it possible that I have newer b body or e body rotors? would like to make sure I have the correct spindles before spending anymore money for rotors I have a ton in this stuff now and the car is not even a disc brake car as it turns out I thought trac pack cars all came with disc brakes but shame on me sort of got duked on this deal
Re: How to id 66-69 b body disc brake spindles [Re: biff426] #328897
05/27/09 12:52 PM
05/27/09 12:52 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Will this picture help?
1967-69 Bendix disc brake set up, for the B body cars.
RF-4C Phantom 69-370 Zweibrucken, Germany
