Re: Roots Blower?
[Re: DARTSPORT340]
#328496
05/25/09 07:34 PM
05/25/09 07:34 PM
Posts: 2,275 Kissimmee, Florida
aarlucas
Kissimmee, Florida
First question, is it a diesel blower or one set up for a car?
Is the blower stripped if it is set up for gas engines? If so, what are their condition?
You want to check the clearances between the leading and trailing edges. If I remember right it should be about .006, however, I recomend you double check that number.
Look for scoring on the end plates too.
Your stock stuff can take the blower IF you keep the boost low. That is done through a low starting compression approx 8-1 and keeping the blower speed low (under driven).
Are you looking at this for the WOW factor or for performance factor? If for the wow factor, great. If for performance, I believe you'd be cheaper just building the engine for the given performance you're looking for.
Re: Roots Blower?
[Re: DARTSPORT340]
#328499
05/25/09 10:43 PM
05/25/09 10:43 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
there are numbers on the bottom of the webbing that will tell a blower company what size it is, 6:71 small case, 6:71 big case, 4:71, 8:71 or?
