A12-727 question. #328457
05/25/09 06:35 PM
05/25/09 06:35 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Is an original A12-727 built to Hemi specs. Pulled my pan off and found a 3.0 lever? Bought a kit from CRT and was told it should be all Hemi bands, drum, etc....
Re: A12-727 question. [Re: cdp] #328458
05/25/09 06:59 PM
05/25/09 06:59 PM
Texas
6packattk Offline
6packattk  Offline
Texas
Mine was not a hemi trans,had 3.8 lever and 4 clutches and mine was numbers matching but have heard different answers so an a-12 expert will chime in soon I hope.I took mine down first time a couple years ago and was kinda disappointed but not that big of deal,mine had broke a flex plate or something and had a chunk broke out of bell housing from its racing days on the bottom where dust cover bolts up,I thought that was a hemi factory slot for access to verter bolts but when removed seen was not factory at all,I cleaned up the area with sawsall and it looks factory now.I put extra clutch on rebuild and went with red clutches and kolene steels so will be better and badder than original anyway.It is my back up till I sell or restore.My oppinion from mine is they just had heavy duty 727 not hemi.If not mine was stripped and redone long before I owned it,but numbers on case are matching my vin but not hemi trans numbers.Hope this helps.....
Re: A12-727 question. [Re: 6packattk] #328459
05/25/09 07:34 PM
05/25/09 07:34 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Not an expert but the 727 in an a12 is just the regular 440 trans, not the hemi version.
I can't afford this. mark
Re: A12-727 question. [Re: cdp] #328460
05/25/09 09:20 PM
05/25/09 09:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No, well it was not supposed to be a "hemi" 727 only the A12's coded for a D21 4-speed were converted from a 3410603 standard HD 4-speed to a "Hemi" 3410605 4-speed. What's stamped on the trans left side below the lever for the first seven (7) digits that will tell you what it was originally? If it reads 093 for the 5th, 6th and 7th digits then it's not a "Hemi" spec trans.
No "Hemi" 727 trans as standard O.E. for an A12 '69 rr or Bee
MikeR
Re: A12-727 question. [Re: A12] #328461
05/25/09 09:29 PM
05/25/09 09:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
A non-Hemi "093" 727 trans out of a '69 383 Super Bee....
Re: A12-727 question. [Re: A12] #328462
05/25/09 09:41 PM
05/25/09 09:41 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
There was no specification for modifying an 093 trans from the factory that I know of? An 093 is an 093 which was standard in 440HP and 383HP cars. The 70 440-6 trans were different than the 383/440HP trans but not in 69. Of course, there is nothing wrong with tricking it up a little for your car today!
