DUAL FEED FUEL LINES ??? #328311
05/25/09 03:07 PM
05/25/09 03:07 PM
Anonymous OP
Anonymous OP
Are dual-feed fuel lines interchangeable from a Mighty Demon 850 to a Holley 4150(850 CFM)??? Thanks! RandyB.
Re: DUAL FEED FUEL LINES ??? #328312
05/25/09 05:12 PM
05/25/09 05:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The main part with the Tee-s will but the bowl fittings wont work.The Demon uses 5/8's O-ring type fittings I believe
Gus
64 Plymouth Savoy
Dana 60
Re: DUAL FEED FUEL LINES ??? [Re: fourgearsavoy] #328313
05/25/09 05:42 PM
05/25/09 05:42 PM
Anonymous OP
Anonymous OP
Thanks Gus! Saved me some time from swapping them. Looks like I'll have to order the line kit(SUM 220100)for the Holley! Hope you're doing well! See ya @ Norwalk this fall! RandyB.
Re: DUAL FEED FUEL LINES ??? #328314
05/25/09 05:55 PM
05/25/09 05:55 PM
Rittman Ohio
Rittman Ohio
Doing great Randy sounds like you are doing very well too I should have my new engine in by early next month
Gus
64 Plymouth Savoy
Dana 60
Re: DUAL FEED FUEL LINES ??? #328315
05/25/09 06:03 PM
05/25/09 06:03 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Looks nice,,,,also looks to have a fitting for a fuel pressure gauge ??
Re: DUAL FEED FUEL LINES ??? [Re: 69CHARGERMD] #328316
05/25/09 10:58 PM
05/25/09 10:58 PM
Anonymous OP
Anonymous OP
Hi Doug! The threaded end hooks into the feed line,off the pump. Gus,shoot me a PM. I wanna know some engine specs on your new motor! Take care,both of you! Randy
