Re: 904 to 8 3/4 drive shaft question....
[Re: JonGottaDemonDad]
#328276
05/25/09 07:20 PM
05/25/09 07:20 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
If the driveshaft you have is from a 904 and a 7 1/4 rear then it will have to be shortened to fit the 8 3/4 as the 8 3/4 rearend is larger to the front than the 7 1/4....
Or do you have more driveshafts around from other cars?
