904 to 8 3/4 drive shaft question.... #328270
05/25/09 01:31 PM
05/25/09 01:31 PM
Escondido, California
JonGottaDemonDad Offline OP
What is the length of a drive shaft on a 1971 Plymouth Duster from a 904 transmission to a 8 3/4" rear end?
I am trying to using the drive shaft I have right now and it appears about 1" to long. Not sure if I can move something to make it fit.
Any advice?
Craig
Re: 904 to 8 3/4 drive shaft question.... [Re: JonGottaDemonDad] #328271
05/25/09 01:55 PM
05/25/09 01:55 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Jon, not what you want to hear, but I had to have mine shortened, found place in National City that was a truck driveshaft serve center.
Re: 904 to 8 3/4 drive shaft question.... [Re: 69DartGT] #328272
05/25/09 01:58 PM
05/25/09 01:58 PM
Anyone know the actual length?
Craig
Re: 904 to 8 3/4 drive shaft question.... [Re: JonGottaDemonDad] #328273
05/25/09 02:26 PM
05/25/09 02:26 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Ideal driveshaft length:
1. Bottom out the slip yoke inside the transmsission
2. Measure the distance between the U-joints front to rear
3. Subtract 1" from this measurement
Re: 904 to 8 3/4 drive shaft question.... [Re: DoctorDiff] #328274
05/25/09 03:08 PM
05/25/09 03:08 PM
NC
HMcCandless_Jr Offline
NC
I have one in the shop, i can let you know tomorrow.
Re: 904 to 8 3/4 drive shaft question.... [Re: JonGottaDemonDad] #328275
05/25/09 03:44 PM
05/25/09 03:44 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Craig
49.27"
Re: 904 to 8 3/4 drive shaft question.... [Re: JonGottaDemonDad] #328276
05/25/09 07:20 PM
05/25/09 07:20 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
If the driveshaft you have is from a 904 and a 7 1/4 rear then it will have to be shortened to fit the 8 3/4 as the 8 3/4 rearend is larger to the front than the 7 1/4....
Or do you have more driveshafts around from other cars?
Re: 904 to 8 3/4 drive shaft question.... [Re: Mopar Ron] #328277
05/25/09 07:28 PM
05/25/09 07:28 PM
Where does the 49.27" begin and end?
Craig
