SB stroker guys, jetting question
#328218
05/25/09 12:48 PM
05/25/09 12:48 PM
Posts: 1,178 Indy
FlyFish
Indy
When you went from stock stroke 360/340 to a 408/416, did you have to jet up a bit to get optimal MPH through the traps? Just asking because my last test session before Pinks looks like it will be rained out. I currently have a Proform 750 dp with 80/88 jets (this was tuned for the 360 before I stroked it). My combo is here if interested: https://board.moparts.org/ubbthreads/show...&PHPSESSID=Thanks in advance!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: SB stroker guys, jetting question
[Re: FlyFish]
#328219
05/25/09 02:58 PM
05/25/09 02:58 PM
Posts: 1,178 Indy
FlyFish
Indy
[Re: FlyFish]
#328220
05/25/09 03:01 PM
05/25/09 03:01 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
only info I can give you is I have a 416 and am running a QF 950 no PV's squared at 88's seems to be working well.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Lil Wedge]
#328223
05/25/09 08:43 PM
05/25/09 08:43 PM
Posts: 1,178 Indy
FlyFish
Indy
I have simular 416, same heads by Ryan, only diffs, Racer Brown 557 solid and Victor intake, Ross pistons, 904 with ptc 8". I run a 750 dp with a proform center jetted 80 square with no pv. and 200 lbs lighter, (3050). Best et to date 10.02 1/4 and 6.27 1/8,@ Chrysler Classic in Columbus last weekend.
Wow! that's moving. What compression are you running? Mine is a pump gas motor through 3" mufflers.
[Re: FlyFish]
#328226
05/25/09 10:52 PM
05/25/09 10:52 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Try the carb the way it was with the smaller motor first, look at the spark plugs, install new ones before the run not the ones you break the motor in on, and then decide if you want to jet up or down. Most new motors like a rich mixture until the get broken in real well, 15 to 20runs sometimes on the small blocks, 6 to 12 runs on the Hemis and BB
[Re: emarine01]
#328228
05/26/09 12:00 PM
05/26/09 12:00 PM
Posts: 316 Ohio
Lil Wedge
Ohio
