What size headers? #327764
05/24/09 09:35 PM
05/24/09 09:35 PM
MB,CAN
PC-CHARGER Offline OP
MB,CAN
Looking to purchase headers for my project. The engine is a 493 CID with Edelbrock RPM heads, a Crower roller with around .600 lift and a FAST fuel injection setup and I think it will make in the 550HP range. Car will be mostly street driven and have a 3" exhaust system but will also be taken for some passes at the local strip. I'm trying to decide whether to go with 1 7/8" tubes and 3" collectors or 2" tubes with 3 1/2" collectors. The 1 7/8" tubes are an easier fit especially with power steering, but I don't want to choke up on the exhaust either. Thoughts?
Re: What size headers? [Re: PC-CHARGER] #327765
05/24/09 10:55 PM
05/24/09 10:55 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
You are saying street car...the smaller 1 7/8 will help you build low end torque plus are much easier to install. 2 inch if you want max hp. I say especially a heavy b body with... say 3.23 or 3.55 gears, go with the smaller tubes.
Re: What size headers? [Re: PC-CHARGER] #327766
05/24/09 11:45 PM
05/24/09 11:45 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
For what your doing 1 7/8 are fine.
Roller cam it and wing it past 7G's
then the 2 inch will be needed!
Snap your neck, mega G-force launch, is all I want!
Re: What size headers? [Re: PC-CHARGER] #327767
05/25/09 03:17 AM
05/25/09 03:17 AM
Nelson-New Zealand
BIG-MIKE-500 ci Offline
Nelson-New Zealand
I run 1-7/8th on a stroker 440(500ci).
Does 12:00@118+ at 4000 lbs & 2:75 gears.
Does 17 mpg Imperial (about 19 US).
Steve Dulcich who does engines in Mopar Muscle Mag, has said he has made 670 HP on 1"7/8th headers.
Re: What size headers? [Re: BIG-MIKE-500 ci] #327768
05/25/09 08:51 AM
05/25/09 08:51 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
1 7/8 would be best.
Re: What size headers? [Re: mopar dave] #327769
05/25/09 08:58 AM
05/25/09 08:58 AM
MB,CAN
MB,CAN
Thanks.... 1 7/8" it is then.
