Re: challenger hoods
[Re: gregok]
#327629
05/24/09 09:55 PM
05/24/09 09:55 PM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
The only difference I know of is '70 hoods don't have the crumple zones. Other than that they should interchange.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
[Re: dOOc]
#327635
05/25/09 12:49 PM
05/25/09 12:49 PM
Posts: 4,165 Florida
cataclysm80
From what I know .. there is a center body line diff .. but they will interchange.
I think what you're saying is that some flat hoods/shaker hoods have a raised spot at the front of the hood for the triangular dodge emblem, while other flat hoods/shaker hoods don't. The hoods without the raised emblem spot could use the "DODGE" letters.
I think the original poster was wanting info on RT hoods though.
Tav
[Re: IMGTX]
#327636
05/25/09 12:52 PM
05/25/09 12:52 PM
cataclysm80
The only other difference is the 71-74 hoods had pull rods for the second latch, the 70's had a tab. There is a raised spot on the underside of the hood for the pull rod mount which uses 2 screws and a bracket. If your installing on a 70 it's no problem. If you have a 70 hood on a 71-74 take care when mounting the rod support bracket so it doesn't dent the hood from underside.
Anyone have a pic of this?
Tav
[Re: 05dakota]
#327637
05/25/09 12:56 PM
05/25/09 12:56 PM
cataclysm80
70 uses different size bolts on hinge to hood than 71-74
Yes, if you use a 71-74 hood with the slightly larger bolts and you have 70 hood hinges, then you'll probably need to file the slot in the hood hinge a little so the bolt will go through. Not too difficult.
Tav
[Re: cataclysm80]
#327646
05/25/09 06:34 PM
05/25/09 06:34 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
As stated above the '70 hoods lacked "crush zones" & use 5/16" bolts to attach to the hood hinges. Late in model year 1970 is when the running change to "crush zones" & 3/8" bolts took place (at least on SHAKER in April & scooped hood in June). Topside of a '70 flat hood with the raised area for the "fratzog" emblem. Not used on "rallye" hood, "DODGE" letters instead. underside of a '70 flat hood (scooped R/T hood is similar) topside of a '73 flat hood ('71-'74 is similar) underside of a '73 flat hood ('71-'74 scooped R/T & "rallye" hood is similar) notice larger reinforcement for nose of hood (under middle "D") --------------- '70 hoods quite often had nose folded down just from closing the hood also compare mounting points for secondary latch two bolts for spring loaded latch in '70 VS. 4 bolts for latch & guide on '71 and newer
