cleaned up and running UPDATE 1
#327347
05/24/09 06:24 PM
05/24/09 06:24 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I got the 47 running well this weekend, finally. Also it's all polished. It will need another go-round to really bring back the paint, but this is good for now. The charging system is working, new battery, cables and rebuilt starter installed, along with the fuel pump last week. Most stuff is working, and I'll get tags for it this week, and a car show next weekend! Won't enter, but will drive there in style.
Re: cleaned up and running
[Re: RUMBLON]
#327349
05/25/09 01:04 AM
05/25/09 01:04 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
very kool that big cruizer should ride nice
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: RodStRace]
#327351
05/25/09 05:43 PM
05/25/09 05:43 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Lucky [Edited by Moparts - Keep it clean]! How are the brakes? How fast can it cruise comfortably on the highway? Looks cool!
CrAzYMoPaRGuY
[Re: bigdad]
#327354
05/25/09 09:16 PM
05/25/09 09:16 PM
RodStRace
Chino Valley
Thanks guys! Crazy, the brakes are good and bad. Most of the time they are fine, but it feels a bit mushy. It also has just dropped to the floor a couple times! I'll bleed them again and check for leaks, but I think the MC is bypassing every once in a great while. Stinks after all that time and money. I SURE won't take it back. Haven't taken it out on the highway yet, since it's not registered. It gets enough looks even before they realize there's no plate. I have got it up to ~45 on the side roads though. Runs good! It's no speed demon with all that mass, but it will cruise. Ron, the radiator is back over a foot, so some major planning would be needed. Daryl, I've never heard of Fred or that song before, it's perfect! Thanks! It's been so cool because everything so far has responded well to just a little TLC. I do have some bad news though. I decided to remove all the tired old heater hoses, since they were working all the time and that isn't needed in AZ! No heater control valve (the guys over on PWHM say they are worth their weight in gold) and a bunch of funky Tees. It was also rubbing on the throttle linkage. So I pull all the hoses off and go to remove a fitting on the bottom of the block to install the normal plug. Darn thing snaps off! I've tried an extractor and heat, and it's not budging. Next step is to tap the thing and install a smaller plug. I'll deal with the mess when I pull the motor for a cleanup. The steering box limits access as it sits. I still want to cruise that mighty big car this weekend.
[Re: RodStRace]
#327355
05/26/09 10:33 PM
05/26/09 10:33 PM
RodStRace
Chino Valley
Update! Got it insured, titled, and registered. Historic plates too! After towing it down to MVD and back, I tried the broken off fitting again, and it came out! Yahoo! Installed the petcock and bolted everything back together and took it out. It runs warmer now without the heaters, and it got hot going down the highway. The guys that deal with these say to check the vacuum advance, and if it's okay, I have the water distribution tube to face... It's okay at lower speed, so I'll be able to make the shows this weekend. Just have the stoplight switch to install when it gets here tomorrow.
[Re: RodStRace]
#327360
05/28/09 05:40 PM
05/28/09 05:40 PM
Posts: 833 Marietta, GA
Joatha
Marietta, GA
That thing looks like it will be a blast to cruise around in. Congrats on getting it going and good luck with it.
1966 Barracuda
1968 Barracuda convertible
1930 Ford Model A (soon to be hemi equipped)
2006 Dodge 3500 4X4 CTD Quad Cab
