cleaned up and running UPDATE 1 #327347
05/24/09 06:24 PM
05/24/09 06:24 PM
Chino Valley
RodStRace Offline OP
Chino Valley
I got the 47 running well this weekend, finally.
Also it's all polished. It will need another go-round to really bring back the paint, but this is good for now.
The charging system is working, new battery, cables and rebuilt starter installed, along with the fuel pump last week. Most stuff is working, and I'll get tags for it this week, and a car show next weekend! Won't enter, but will drive there in style.
Re: cleaned up and running [Re: RodStRace] #327348
05/24/09 07:32 PM
05/24/09 07:32 PM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Re: cleaned up and running [Re: RUMBLON] #327349
05/25/09 01:04 AM
05/25/09 01:04 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
very kool that big cruizer should ride nice
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: cleaned up and running [Re: fstfish66] #327350
05/25/09 01:37 AM
05/25/09 01:37 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Nice.
Re: cleaned up and running [Re: RodStRace] #327351
05/25/09 05:43 PM
05/25/09 05:43 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Lucky [Edited by Moparts - Keep it clean]!
How are the brakes?
How fast can it cruise comfortably on the highway?
Looks cool!
CrAzYMoPaRGuY
Re: cleaned up and running [Re: RodStRace] #327352
05/25/09 06:11 PM
05/25/09 06:11 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
MAN that hood is LOOOOOOG
you could put a V10 in there
have fun crusin' it Ron...
Re: cleaned up and running [Re: Mopar Ron] #327353
05/25/09 06:58 PM
05/25/09 06:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Thats MIGHTY BIG CAR !!
Listen Fred sing about it
http://www.youtube.com/watch?v=6kk3Nh2u6tA
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: cleaned up and running [Re: bigdad] #327354
05/25/09 09:16 PM
05/25/09 09:16 PM
Chino Valley
Chino Valley
Thanks guys!
Crazy, the brakes are good and bad. Most of the time they are fine, but it feels a bit mushy. It also has just dropped to the floor a couple times!
I'll bleed them again and check for leaks, but I think the MC is bypassing every once in a great while. Stinks after all that time and money. I SURE won't take it back.
Haven't taken it out on the highway yet, since it's not registered. It gets enough looks even before they realize there's no plate. I have got it up to ~45 on the side roads though. Runs good! It's no speed demon with all that mass, but it will cruise.
Ron, the radiator is back over a foot, so some major planning would be needed.
Daryl, I've never heard of Fred or that song before, it's perfect! Thanks!
It's been so cool because everything so far has responded well to just a little TLC.
I do have some bad news though. I decided to remove all the tired old heater hoses, since they were working all the time and that isn't needed in AZ! No heater control valve (the guys over on PWHM say they are worth their weight in gold) and a bunch of funky Tees. It was also rubbing on the throttle linkage. So I pull all the hoses off and go to remove a fitting on the bottom of the block to install the normal plug. Darn thing snaps off!
I've tried an extractor and heat, and it's not budging. Next step is to tap the thing and install a smaller plug. I'll deal with the mess when I pull the motor for a cleanup. The steering box limits access as it sits. I still want to cruise that mighty big car this weekend.
Re: cleaned up and running [Re: RodStRace] #327355
05/26/09 10:33 PM
05/26/09 10:33 PM
Chino Valley
Chino Valley
Update!
Got it insured, titled, and registered. Historic plates too!
After towing it down to MVD and back, I tried the broken off fitting again, and it came out! Yahoo!
Installed the petcock and bolted everything back together and took it out. It runs warmer now without the heaters, and it got hot going down the highway. The guys that deal with these say to check the vacuum advance, and if it's okay, I have the water distribution tube to face...
It's okay at lower speed, so I'll be able to make the shows this weekend.
Just have the stoplight switch to install when it gets here tomorrow.
Re: cleaned up and running [Re: RodStRace] #327356
05/27/09 12:26 AM
05/27/09 12:26 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Sweet
Re: cleaned up and running [Re: 76dodgeboy] #327357
05/27/09 07:15 PM
05/27/09 07:15 PM
Chino Valley
Chino Valley
Brake switch is in, dwell, timing and carb set (was way off), and it runs well!
The speedo isn't happy, so I'll hold off on the cable for now. I got another complete dash, so I'll check that one out. Now everything works but the clock, the radio and the speedo. Even the fuel gauge came back!!!
Re: cleaned up and running [Re: RodStRace] #327358
05/28/09 02:55 AM
05/28/09 02:55 AM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
what's that thing got stock six or flathead 8?
Re: cleaned up and running [Re: migsBIG] #327359
05/28/09 10:58 AM
05/28/09 10:58 AM
Chino Valley
Chino Valley
Flathead 6. The models for 1947 were (lowest to highest) Royal, Windsor, Windsor Town & Country (all 6 cyl), and Saratoga, New Yorker, New Yorker Town & Country (8 cyl).
Re: cleaned up and running [Re: RodStRace] #327360
05/28/09 05:40 PM
05/28/09 05:40 PM
Marietta, GA
Joatha Offline
Joatha  Offline
Marietta, GA
That thing looks like it will be a blast to cruise around in. Congrats on getting it going and good luck with it.
1966 Barracuda 1968 Barracuda convertible 1930 Ford Model A (soon to be hemi equipped) 2006 Dodge 3500 4X4 CTD Quad Cab
Re: cleaned up and running [Re: Joatha] #327361
05/31/09 09:28 PM
05/31/09 09:28 PM
Chino Valley
Chino Valley
Well, it still doesn't like long 35+ cruising. Took the fuel line off the tank and it just dribbled out, so a tank clean is in the future, along with a pair of straps. The nuts are badly rusted, and the better one I already snapped.
Checked the valves (only one tight), cleaned the covers and replaced the gaskets. Dropped the oil pan.
It had a broken distributor drive gear in the bottom! It also has a big braze patch on the bottom of the pan. Cleaned out the grime and chunks, will have it hot tanked this week. I did get to stroll around town Saturday, and it keeps running smoother. I hope to get it back together shortly.
