broke lader bar off of diff housing. with video #327310
05/24/09 06:04 PM
05/24/09 06:04 PM
so cal
cmcgee123 Offline OP
so cal
http://www.youtube.com/watch?v=zSbcgH2A4...player_embedded
finally got the 6pt in the car and decided to make some full power runs and on the second run on the bottle it broke off the line. i launch the car on nitrous off the foot brake and it normally 60' 1.39-1.42.
the lader bar bracket broke off the diff housing on the launch most likely cause by looking at it would be too cold of welds. "if you want something done right" this is the only thing i didnt personally do to the car was the rear suspension. oh well
now my question when the lader bar broke it bent the 8 3/4 housing pretty bad. should i have it straightened, get a moser 8 3/4 fabbed housing or just go dana. the housing that is in it is back braced.
what to do
single choice
Votes accepted starting: 05/24/09 05:04 PM
Re: broke lader bar off of diff housing. with video [Re: cmcgee123] #327311
05/24/09 07:16 PM
05/24/09 07:16 PM
so cal
so cal
ne one got a dana? 51" axle to axle or close to that size?
Re: broke lader bar off of diff housing. with video [Re: cmcgee123] #327312
05/24/09 07:20 PM
05/24/09 07:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
did the weld just break off oh the tube or did it pull a piece of the tube with it? if it just broke off it had no penetration.
Re: broke lader bar off of diff housing. with video [Re: Quicktree] #327313
05/24/09 07:39 PM
05/24/09 07:39 PM
so cal
so cal
the welds broke off the tube. i told the guy that installed the lader bars he needs to get a better welder. i only have like 60 passes on that set up.the deepest nick the welds took out of the housing was only .040" so the welds were just not penetrating enough. unfortunately its gonna cost me a decent ammount of money to fix it. but at least i didnt put my baby in the wall.
Re: broke lader bar off of diff housing. with video [Re: Quicktree] #327314
05/24/09 07:46 PM
05/24/09 07:46 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I had the very same thing happen a number of years ago at Dragway 42, I got lucky and cut the end's off and re-welded the bracket's and end's back on with the jig and friend who is a professional welder, welded it all back together,, the first guy only welded one side of each bracket, I ran that housing for a couple more years and then built the Dana and never looked back.
Re: broke lader bar off of diff housing. with video [Re: dartman366] #327315
05/24/09 08:08 PM
05/24/09 08:08 PM
so cal
so cal
i already cut all the good parts off the housing so im stuck with only 2 options now moser fabbed housing or dana. im leaning towards the dana. the car is only gonna get faster so do it right at least the seccond time
Re: broke lader bar off of diff housing. with video [Re: cmcgee123] #327316
05/24/09 08:13 PM
05/24/09 08:13 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Yes...........50" flange to flange and I hope I never break it.
IMO, ditch the 8 3/4". I shelled all the teeth off the ring gear
and the housing was twisted from trans-brake launches with
a 340 @ 2830 lbs.
Re: broke lader bar off of diff housing. with video [Re: cmcgee123] #327317
05/24/09 10:41 PM
05/24/09 10:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
That is Irwindale, correct? How are the people behaving there now? A freind of mine in SO CA won't go there now since he had a bad night there several years ago, ricers with guns and attitudes That was before the shootings at the track
Re: broke lader bar off of diff housing. with video [Re: Cab_Burge] #327318
05/25/09 02:56 PM
05/25/09 02:56 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Got a Dana and local... check your PMs
Re: broke lader bar off of diff housing. with video [Re: Cab_Burge] #327319
05/25/09 06:03 PM
05/25/09 06:03 PM
so cal
so cal
99% of the time there arent problems there. but just like anywhere a lot of people get togather there are bound to be problems.
Re: broke lader bar off of diff housing. with video [Re: cmcgee123] #327320
05/25/09 06:46 PM
05/25/09 06:46 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Yep, was there not too long ago and a guy coming down the return lanes in a truck was angry since he thought he lost and the other guy redlit..told his friends to go to the parking lot so they could kick his a.., sad that some people try to ruin things for others. Havent seen your car run out there but ive seen pictures of it before, go with a dana IMO, goodluck with your car maybe ill see it there one night.
Re: broke lader bar off of diff housing. with video [Re: 69B3GT] #327321
05/26/09 01:17 AM
05/26/09 01:17 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Dana...
Thery're out there. I just bought a truck Dana 60 yesterday for $120 off Craig's list from a guy 10 minutes from my house. I'll narrow it to fit my chassis and get Mopar ends on it. My 8 3/4 is definitely on borrowed time now that I'm hotting it with the spray.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: broke lader bar off of diff housing. with video [Re: 67Charger] #327322
05/26/09 05:11 PM
05/26/09 05:11 PM
so cal
so cal
gonna pick up b170duster's dana its got 4.88's in it right now i figure i'll make one 1/8th pass with those gears then throw 4.30's in it
