I have picked up my friend's 440 short-block that was removed from a REAL V-Code 1970 Cuda. He was told the engine was replaced long ago with a "replacement" engine. It has no VIN number on the lower pad on the right side. On the upper "Pad" is the following markings:
G 440 (Maltese Cross)-(Big "X") -H P
10 - 16 HP2
The numbers on side of the block(passenger) are:
7 - 28 -69
2536430 - 7
My question is: Could this be a "Warranty" replacement block that was cast in late 1969 ? I know that "G" is for 1971 , 440 is the cubic inch. I believe that the Maltese Cross & the big "X" are for undersize Main & Rod bearings , however I'm not sure why the "HP" on top row and "HP2" on bottom? Also what is the "10-16" represent? I hope these are not stupid questions
and I sincerely appreciate our knowledgeable forums' members responding when time permits!
I hope everyone is having a GREAT Memorial week-end
Stuck at home in broke California! ...............
