Bench racing 383 ET predictions #326774
05/23/09 11:39 PM
05/23/09 11:39 PM
NC
DARTSPORT340 Offline OP
super gas
super gas
NC
Ok i'm bored to death figured I'd post a what will it run.
I plan on putting a 383 in my Dart, It's gonna be .030 over Stock 906 heads, trw pistons lets say 10-1cr.,stock rods and crank. MP .533 cam or maybe comp 305H, tm-6 intake and a good set of headers. Trans is going to be a glide, stock 1.76 gear 10" converter, and a Dana with 4.56's and a 30 or 31" tall tire. The car should weight about 2700 with me and fuel....hopefully. I plan on going to 440source heads this spring so I figured I'd go ahead and give it enough cam to support those.
Re: Bench racing 383 ET predictions [Re: DARTSPORT340] #326775
05/24/09 01:09 AM
05/24/09 01:09 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
With almost the same combo save for the Mopar 284/484 I had in the engine(now a 292/509)I went 11.60 with a 3560#(me and fuel all steel except hood) Demon 5.13 Dana 31.25 tall tires and stock 727 with TA 3800 converter.
Nautilus Racing-
Re: Bench racing 383 ET predictions [Re: DARTSPORT340] #326776
05/24/09 01:24 AM
05/24/09 01:24 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
The .533 may hit the pistons if they don't have valve reliefs but a .509 will fit with steel shims Must be the extra duration.
I know of a similar combo but with a 727, J converter and a .509 that would run 7.40's@95-96 in a Dart.
It ran really well for a basic combo, 383 with replacement TRW's set .015 out of the hole, stock 906's w/2.08's, MP .509, TM6, 4779 holley, CPPA headers & 3" exhaust. It didn't need a ton of RPM to work either, footbrake it to 4k, shift at 6,200 and run it out the back.
Re: Bench racing 383 ET predictions [Re: MoparJoe] #326777
05/24/09 12:17 PM
05/24/09 12:17 PM
NC
super gas
super gas
NC
I may run a .509 I was just worried it may not be enough cam when I go to aluminum heads...
Re: Bench racing 383 ET predictions [Re: DARTSPORT340] #326778
05/24/09 12:20 PM
05/24/09 12:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
the 509 is a good cam. degree it at 104 to 102 for that long first gear
