14X7 rims on 71 B-body #325911
05/22/09 07:55 PM
05/22/09 07:55 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Day All
Finally got the 14X7 cop car rims painted for the wifes 71 SuperBee (EL5 Butterscotch).
The plan is to run Goodrich T/A radials with 235/60 on the rear and 215/60 on the front.
Does anyone see a problem with this set up?
Also, looking for opinions on what speedo pinion to run with this set-up (3:55/Torque Flight.
As always thanks to all who respond.
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325912
05/22/09 09:05 PM
05/22/09 09:05 PM
IA
landon1 Offline
landon1  Offline
IA
i ran 235/60s on the rear and 225/60s up front on my 71 Plymouth...they look small imo...24.5" diameter i believe on the rears
i have 225/70s all around now - look much better at 26.5"
both sets of tires were BFG Radial TA
here's a pic with the old tires to show what i mean - the wheelwells on the dodges may be a lil smaller, which would help
'71 Satellite Sebring 440
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325913
05/22/09 09:47 PM
05/22/09 09:47 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Other than the fact that it'll look like you are running around on donut sized spares it should work fine.
Re: 14X7 rims on 71 B-body [Re: DaytonaTurbo] #325914
05/22/09 09:52 PM
05/22/09 09:52 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I agree, on a 71, I'd consider 275's to be the smallest I'd go. I run 245's on the back of my '67 plymouth. They look smallish to me even in those tiny wheelwells.
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325915
05/22/09 09:59 PM
05/22/09 09:59 PM
The car needs 15's
Re: 14X7 rims on 71 B-body #325916
05/22/09 10:48 PM
05/22/09 10:48 PM
IA
landon1 Offline
landon1  Offline
IA
i do like some 15" wheels(mainly just to go wider), but the 14" wheel is very nice imo...i don't think that 225s look small - for me, it's the diameter that makes the difference. the 225/70s are basically stock appearing, but the 60 series 14" tires are just too small in diam. for my taste
car's dirty, but here's an idea on width and how much nicer they fill out the wheel wells
(note the black soot on the left side...this is on the way to the shop to pull the motor for rebuild)
Re: 14X7 rims on 71 B-body [Re: landon1] #325917
05/22/09 11:09 PM
05/22/09 11:09 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Most owners go to a 15 inch wheel because of the availablity of tire sizes. I went from 14s to 15s for this reason as well. The 71 B-bodies have huge rear wheel wells and small tires get lost in there. For your wheel choice I'd find a speedo gear with 37 teeth.
Ron
275x60x15 rear, 235x60x15 front
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325918
05/22/09 11:31 PM
05/22/09 11:31 PM
I'm running a 15x7 rim all the way around on the car in my sig.
P235/R6015, 26.1" tire up front
P255/70R15 29.04" tire out back
I have 4:10 gear and IIRC I have a 39 tooth speedo gear.
IMHO 14"s are a bit too small, but it's your overall tire size that's a tad short.
Your rear tires will look like my fronts...
Your 235/60 = a 25.1" tire, with 3:55's you will want a 36-39 tooth speedo according to the chart in the archives...
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325919
05/23/09 01:32 AM
05/23/09 01:32 AM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
I like the original look on mine (14 x 6). You can check out the car here. Kim
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325920
05/23/09 02:58 AM
05/23/09 02:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My first set of wheels on my '71 Charger were the 14" Magnum 500 rims with 235x60x14" tires front and rear. They looked good, and worked OK, except in hard cornering. With the stock suspension the car leaned really hard in corners, but once I upgraded the Torsen bars and added sway bars, the small tires did not like the slomon course. When I got through the course the sidewalls of the tires were scuffed up.
I then got 15"x7" rims with 255x60x15" tires which worked much better. I think with the right offset you might be able to get something like 15x8" rims with 275 width tires in the front, and I currenty run 15x10" rear rims with the MT street radial tires. I don't know the metric equivlent size, but I think 295's should fit?
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325921
05/23/09 05:16 AM
05/23/09 05:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Finally got the 14X7 cop car rims painted .......
Anyone else wondering where he obtained 14" cop car rims?
Re: 14X7 rims on 71 B-body [Re: 6bblgt] #325922
05/23/09 01:02 PM
05/23/09 01:02 PM
usa
Mopar1970440 Offline
usa
cop wheels...should be 15's. Maybe he has some stocker 14 inch steel wheels.
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325923
05/23/09 01:43 PM
05/23/09 01:43 PM
Ohio in the USA
O
O
Ohio in the USA
My Bad
I ment to say 15X7 Cop Car rims.
(either to much or not enough caffine....)
Re: 14X7 rims on 71 B-body [Re: Omni Source 1] #325924
05/23/09 02:25 PM
05/23/09 02:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the 215/60/15 is a pretty short tire
I'd put 235/60/15 front & 255/60/15 rear
or
245/60/15s all around (nice fit on 7" wheel & '71 "B")
