Staggered shock valving #325854
05/22/09 06:28 PM
05/22/09 06:28 PM
Ansonia, CT
CJK440 Offline OP
CJK440  Offline OP
Ansonia, CT
On launch I pulling the left front. Rear shock are comp engineering adjustables both set at 50/50.
I'm thinking about setting just the pass side to 60/40 or 70/30 to help plant that side harder.
Any reason why not??
Re: Staggered shock valving [Re: CJK440] #325855
05/22/09 10:47 PM
05/22/09 10:47 PM
try adjusting the right front looser than the left front, adjust the left rear stiffer than the right rear Use what ever makes the 60 ft. times the best
