Cooling fan clearance issues #325740
05/22/09 02:01 PM
05/22/09 02:01 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
I've got a 72 demon with a 360 Magnum engine and a stock radiator. I want to put the popular chevy hhr fan in because it seems like it will do the trick and is also very cheap.
However, I don't believe theres going to be enough room as is. Theres about 3 1/4" clearance between the radiator and the water pump pulley bolts.
What are some ways I can gain a lot of clearance in this setup?
I could probably trim about 1/4"...maybe 1/2" off the fan shroud. Are there any short water pumps available? I'm running the LA style pump and timing cover, any differences in thickness between the Magnum and LA style timing covers and water pumps?
I would prefer not to move the radiator support as I don't have any way of welding it back together.
Any ideas?
Re: Cooling fan clearance issues [Re: chache876] #325741
05/22/09 02:02 PM
05/22/09 02:02 PM
Costa Mesa, CA
Costa Mesa, CA
The HHR fan is 4 1/2" thick I believe
Re: Cooling fan clearance issues [Re: chache876] #325742
05/22/09 04:22 PM
05/22/09 04:22 PM
Any ideas?
mill the tcover so the vanes are closer to the tcover flat area which will also make your water pump vanes more efficient(same as a fan shroud does with the fan),just use shorter bolts/washers so they dont bottom out(check them) & readjust your crank/alt pulleys if neccessary.
Re: Cooling fan clearance issues [Re: RapidRobert] #325743
05/22/09 04:51 PM
05/22/09 04:51 PM
Costa Mesa, CA
Costa Mesa, CA
Are you talking about milling the water pump side of the tcover?
I guess if I had to modify the radiator support I was thinking of just cutting out the section circled in the picture and just moving the radiator back a little bit. How integral is that to the frame?
If I cut it out and leave it out will there be a lot of flexing?
Re: Cooling fan clearance issues [Re: chache876] #325744
05/22/09 04:56 PM
05/22/09 04:56 PM
correct
Re: Cooling fan clearance issues [Re: RapidRobert] #325745
05/23/09 03:14 PM
05/23/09 03:14 PM
Costa Mesa, CA
Costa Mesa, CA
bump, can I cut that piece and be okay?
Re: Cooling fan clearance issues [Re: chache876] #325746
05/23/09 04:32 PM
05/23/09 04:32 PM
You're fine milling the tcover which will move everything(fan assy) rearward & the alt can be easily spaced rearward to keep the pulley alignment correct but see where you are at with the crank pulley. Mock everything up before you cut and you ideally want ~.040" between the vanes and the tcover flat(including gasket) and on the water pump you can press the vanes closer(forward) to the pump body body(support the front shaft when you do so)(which makes the WP even more efficient)and which allows you to mill the tcover more to give you even more fan to rad clearance DEPENDING if your pulleys can be spaced into alignment. also the face of the harmonic dampener can be milled so the crank pulley will sit further rearward. that'd be extreme & I did not have to do that myself but I wanted to cover everything for you.
Re: Cooling fan clearance issues [Re: chache876] #325747
05/23/09 04:34 PM
05/23/09 04:34 PM
NH
72challorange Offline
He's Game
He's Game
NH
don't cut the radiator support.
Tom
Re: Cooling fan clearance issues [Re: 72challorange] #325748
05/23/09 04:41 PM
05/23/09 04:41 PM
Oh I thought he was asking about the tcover. My mistake
Re: Cooling fan clearance issues [Re: chache876] #325749
05/23/09 04:51 PM
05/23/09 04:51 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
If you have a good factory radiator,shroud and correct fan,why do you think you need something else ?
Re: Cooling fan clearance issues [Re: I go fast] #325750
05/23/09 05:49 PM
05/23/09 05:49 PM
Costa Mesa, CA
Costa Mesa, CA
Because I don't have a factory fan or shroud!
Re: Cooling fan clearance issues [Re: chache876] #325751
05/23/09 05:58 PM
05/23/09 05:58 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
There has got to be a better way. maybe two electrics mounted diagonally on the rad, clearing that pulley?
I just put a huge evans rad with big spal fans in my charger...we moved the rad up just a bit and trimmed the fans very very slightly to get it to fit....clearly yours and my situation are apples and oranges...but it shows that there is more than one way to skin a cat.
I'd hesitate to do anything that will screw you down the road...like milling everything in site on the front of the motor. That's nuts!
or locate a factory shroud
Re: Cooling fan clearance issues [Re: Pool Fixer] #325752
05/23/09 06:08 PM
05/23/09 06:08 PM
Costa Mesa, CA
Costa Mesa, CA
I mean I suppose I could get an aftermarket aluminum radiator that is thinner...but then I gotta figure out how to mount that. Argh!
Re: Cooling fan clearance issues [Re: chache876] #325753
05/23/09 06:17 PM
05/23/09 06:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I have a similar problem going. I need to find a fan clutch that is about 1/4 to 1/2 inch shorter. My fan hits the radiator under hard acceleration.
I tried to get a shorter clutch and nobody carries one any shorter than 1 1/2" from fan blade mount bosses to the end of the shaft that bolts to the pulley/pump.
I tried a Northern brand aluminum radiator with no luk, it won't mount any better than the stocker 26" one that is on there now. That one is sort of shoved in there as it is a 22" core support.
I haven't had any luck finding what I need to make it work. The factory aluminum blade fan that I have on it must flex under hard load as it is fine unless it is floored.
I have a Schemaker adjustable torque strap and it isn't roking side to side but ight be inching forward somehow.
Anybody know of a shorter clutch than what I described?
I want my fair share
Re: Cooling fan clearance issues [Re: SomeCarGuy] #325754
05/23/09 06:26 PM
05/23/09 06:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
It looks from the pic that you can move the radiator closer to the support by taking the radiator to a shop and have them move the tanks back and reweld the mounts, as for the guy whos looking for a clutch, go to napa and ask for a 91 jaguar unit,
Re: Cooling fan clearance issues [Re: ademon] #325755
05/23/09 06:27 PM
05/23/09 06:27 PM
SomeCarGuy Offline
SomeCarGuy  Offline
I'll check it out thanks!
Re: Cooling fan clearance issues [Re: SomeCarGuy] #325756
05/23/09 06:30 PM
05/23/09 06:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
You have to use the bushing that comes with the Jag unit, i have this setup on my Demon
Re: Cooling fan clearance issues [Re: ademon] #325757
05/23/09 06:39 PM
05/23/09 06:39 PM
SomeCarGuy Offline
SomeCarGuy  Offline
That won't be bad as long as it is shorter overall. I don't need much to be gold.
Re: Cooling fan clearance issues [Re: SomeCarGuy] #325758
05/24/09 12:29 AM
05/24/09 12:29 AM
Costa Mesa, CA
Costa Mesa, CA
Well I guess its looking like the easiest thing to do would be just to return the fan and go with a dual setup or hopefully find a good enough single fan that actually works.
Any recommendations on single or dual setups with fan shrouds? Right now its pretty much a stock magnum 360 with some bolt ons, but I would like to have something that will work incase I decide to do some more with the engine.
Re: Cooling fan clearance issues [Re: chache876] #325759
05/24/09 08:30 AM
05/24/09 08:30 AM
NH
He's Game
He's Game
NH
Why not get a shroud and clutch fan?
Tom
At least a clutch fan, but a shroud may be needed depending on any heating issues.
I run a summit rad and northern shroud with a clutch fan, had to put a 180 stat in it since it wouldn't get over 150 cruising down the road with the 160 stat.
