69 Road Runner, 22" Radiator replacement?
#325694
05/22/09 01:19 PM
05/22/09 01:19 PM
Posts: 79 North NJ
a6t9vette
North NJ
I'm looking to upgrade/replace the incorrect radiator in my 69 Road Runner (383/727/non AC) since it recently started running a little hotter then normal. It seems like all places selling aluminum replacement radiators only sell 26" models. The radiator support in the car has a 22" opening, so I dont imagine i can just drop a new radiator with a 26" core in, and I really dont want to swap out the radiator support (I assume the optional OEM 26" radiators required a different support) to get better cooling. Any ideas or recommendations would be great. Thanks, Bob
69 Road Runner, numbers matching 383, Auto.
Re: 69 Road Runner, 22" Radiator replacement?
[Re: a6t9vette]
#325695
05/22/09 01:51 PM
05/22/09 01:51 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
You CAN bolt a 26" rad in a 22" support, but you'll have to drill some holes and a portion of the rad will be blocked off. You can also replace the portions of the support the rad bolts to using aftermarket pces.
Personally, I would get a used 22" and recore with a good quality core or source a 22" repop (sorry, don't know who carries them)
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: satgtx]
#325697
05/22/09 05:31 PM
05/22/09 05:31 PM
Posts: 79 North NJ
a6t9vette
North NJ
I would re-do it if it was an original or correct unit, but I dont see the point in recoring an incorrect radiator.
