Wheel spacers with 5/8 studs? #325186
05/21/09 10:10 PM
05/21/09 10:10 PM
NC
DARTSPORT340 Offline OP
super gas
super gas
NC
Is it ok to run wheel spacers with 5/8 studs? I've got alittle issue with my new wheels and need to bump them out a bit. Would a good set of spacers be ok?
Re: Wheel spacers with 5/8 studs? [Re: DARTSPORT340] #325187
05/21/09 10:29 PM
05/21/09 10:29 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
if you need any custom made...contact Jerry
on this site..
this is his website..he made me a set custom to order...
cheapst
http://www.superiordesignconcepts.com/
his home page on Moparts
https://board.moparts.org/ubbthreads/showprofile.php?Cat=0&User=6272&what=login
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Wheel spacers with 5/8 studs? [Re: cheapstreetdustr] #325188
05/21/09 10:47 PM
05/21/09 10:47 PM
NC
super gas
super gas
NC
Sweet thanks!!! I'm trying to "small tire" my chassis car and even with 1 7/8bs wheels it still needs alittle more
Re: Wheel spacers with 5/8 studs? [Re: DARTSPORT340] #325189
05/22/09 07:53 AM
05/22/09 07:53 AM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
I gave a friend of mine a set of dimensions for a set of wheel spacers and he created an Auto-CAD file for me.
I purchased the 6061-T6 Aluminum plate and took it and the Auto-CAD file to a local shop that does Water-Jet cutting and came home with a beautiful set of spacers.
Next, I drilled 4 small holes in the spacer and drilled corresponding pilot holes in the wheel and screwed the spacer into the inside of the wheel.
Why did I do this? Because fixing the spacer inside the hub of the wheel effectively makes the hub thicker and look like a single piece of material.
Paul
Re: Wheel spacers with 5/8 studs? [Re: 74DusterP457] #325190
05/22/09 08:03 AM
05/22/09 08:03 AM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
i think the question was::: is it ok to run wheel spacer ??? the answer is YES, it is ok..make sure you have at least the 3" or 4" long studs in place...good luck..
Re: Wheel spacers with 5/8 studs? [Re: BILLYJAY] #325191
05/22/09 08:06 AM
05/22/09 08:06 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have run up to 1" spacers with 5/8 studs.Just use a good fitting spacer that registers on the axle hub.
Re: Wheel spacers with 5/8 studs? [Re: B G Racing] #325192
05/22/09 11:39 AM
05/22/09 11:39 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
my spacers are hub centric so you don't have too much slop that can end up causing an off balance condition. also mine are made from 6061 and not brittle like the cast ones. anything over 1" thick should be an adapter with its own set of studs.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Wheel spacers with 5/8 studs? [Re: Jerry] #325193
05/22/09 12:39 PM
05/22/09 12:39 PM
NC
super gas
super gas
NC
I remeasured today and I think I can get by with 3/4 to 1" so I should be good to go then. I hate having to put cragar super tricks in place of my welds but it's the only 10" wheel I could find with such little backspacing
