Time to figure out what we have hemi wise. #325177
05/21/09 09:38 PM
05/21/09 09:38 PM
Northeast, Arkansas
Dodgeman67 Offline OP
Northeast, Arkansas
Time to get on this hemi and figure out where we are so we can figure out where we need to go with all the parts.
I borrowed a barret (sp) from a buddy and jumped into this having never done it before it was interesting to say the least.
If I did something wrong pleae let me know.
Here are a few pictures.
Here are some pictures.
Re: Time to figure out what we have hemi wise. [Re: Dodgeman67] #325178
05/21/09 11:16 PM
05/21/09 11:16 PM
If you angle the head (any head, not just the hemi heads)so one side is higher than the other and place the plate so the hole is on the high side next to the edge of the combustion chamber it makes a lot easier to fill the combustion chamber, Liquid flows down hill in other words Expereince is a great teacher I bought a needle tip for a hand held grease gun and use that to place a very thin line of grease around the chambers to seal the fill plate to BTW, what type of liquid are you using for the measuring? How many CC difference did you find between the four combustion chambers? Or did you check all four, if not you should
Re: Time to figure out what we have hemi wise. [Re: Cab_Burge] #325179
05/24/09 02:00 PM
05/24/09 02:00 PM
Northeast, Arkansas
Northeast, Arkansas
Sorry I missed your post.
I didn't know what to use, so I used water to check with, I have since been told some use alcohol and some use cleaning solvent?
I didn't check all the combustion chambers, but I will.
When I start cleaning up the runners I will cc everything again as I go.
Like I said I am new at this and any advice would be appreciated.
Thanks,
Jeff
Re: Time to figure out what we have hemi wise. [Re: Dodgeman67] #325180
05/24/09 04:46 PM
05/24/09 04:46 PM
Check them all before trying to even them up I have never really treid to even the port runners up so I can't say if it is worth doing or not, maybe worth doing on a all out go for broke race motor I use rubbing alcholol with BLUE food coloring in the burret Any color will work
Re: Time to figure out what we have hemi wise. [Re: Cab_Burge] #325181
05/24/09 04:50 PM
05/24/09 04:50 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Also add a little red food coloring to your water, makes it much easier to read...Phill
