Coil Testing? #32484
12/02/06 10:01 AM
12/02/06 10:01 AM
Edgartown, MA/ Greene, ME
CharlieB Offline OP
CharlieB  Offline OP
How would you test a coil?
Re: Coil Testing? [Re: CharlieB] #32485
12/02/06 10:44 AM
12/02/06 10:44 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Test by checking resistance on the primary winding, across the positive and neg. terminals and also by checking secondary resistance, from the + or - to the tower. Coils specs are all different, but if it's a mopar style coil you should see between 1.5-2.0 ohms on the primary and about 9000- 12000 ohms on the secondary.
Re: Coil Testing? [Re: rrunner] #32486
12/02/06 02:05 PM
12/02/06 02:05 PM
Los Angeles County, California
arod15 Offline
arod15  Offline
Like this http://mymopar.com/coiltest.htm using a multimeter.
Re: Coil Testing? [Re: arod15] #32487
12/02/06 05:25 PM
12/02/06 05:25 PM
CharlieB Offline OP
CharlieB  Offline OP
Thanks guys- It ain't the coil
Re: Coil Testing? [Re: CharlieB] #32488
12/02/06 05:58 PM
12/02/06 05:58 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
sorry to hear that. I was going to suggest a person you want to watch jump around a bunch. Have them hold the coil wire and you spin the engine over.
Re: Coil Testing? [Re: TheBlueBeast] #32489
12/02/06 06:38 PM
12/02/06 06:38 PM
Also check each post to the case to make sure the winding isnt shorted to ground.
Re: Coil Testing? #32490
12/02/06 07:21 PM
12/02/06 07:21 PM
CharlieB Offline OP
CharlieB  Offline OP
I've got a complete FBO Elec ignition system freshly installed in June. Reg, Bal resistor, coil check out OK. Will be looking at ECU and Dist next. The Bees' probably in for the winter here in Maine so I guess I've got the whole winter to figure it out
Re: Coil Testing? [Re: CharlieB] #32491
12/02/06 08:35 PM
12/02/06 08:35 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Do you have swithced ign at the + term? if so with a test light crank the engine and check the - term, is it pulsing?
Re: Coil Testing? [Re: CharlieB] #32492
12/03/06 08:20 AM
12/03/06 08:20 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Charlie, Do you have the complete FBO set-up? What type of problems are you having?
