How do I know if my 60' times are correct for my Car #324709
05/21/09 01:38 PM
05/21/09 01:38 PM
Danville, NH
Mopar_Mike Online content OP
Mopar_Mike  Online Content OP
Danville, NH
Is there a comparable chart that will show where you should be at based on 60' time, and/or ET and or MPH.
My car is going 1.75 60' 12.2-4 at 107-109mph
I am trying to figure where I should work to get the car to a lower ET.
Thanks.
RS23L7 4-Speed
Re: How do I know if my 60' times are correct for my Car [Re: Mopar_Mike] #324710
05/21/09 02:06 PM
05/21/09 02:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it's way off, you should be in the 1.56- 1.65 range imo.
Re: How do I know if my 60' times are correct for my Car [Re: Quicktree] #324711
05/21/09 02:09 PM
05/21/09 02:09 PM
Danville, NH
Danville, NH
Meaning a 12.2 ET should yield a 1.56-1.65 60' time?
RS23L7 4-Speed
Re: How do I know if my 60' times are correct for my Car [Re: Mopar_Mike] #324712
05/21/09 02:11 PM
05/21/09 02:11 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
meaning you're leaving et on the table in your 60'.. I was going 11.70s at 113-114 with a 1.61 60'.
Re: How do I know if my 60' times are correct for my Car [Re: Mopar_Mike] #324713
05/21/09 02:34 PM
05/21/09 02:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I guess your not that far off. but you may want to work on it a little
Re: How do I know if my 60' times are correct for my Car [Re: Quicktree] #324714
05/21/09 02:48 PM
05/21/09 02:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What is the car and the combo ?? The weight , gear , cam , heads and so on have alot to do with your 60. Ron
Re: How do I know if my 60' times are correct for my Car [Re: 383man] #324715
05/21/09 03:01 PM
05/21/09 03:01 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: How do I know if my 60' times are correct for my Car [Re: sixpackgut] #324716
05/21/09 04:03 PM
05/21/09 04:03 PM
NH
72challorange Offline
He's Game
He's Game
NH
That calculator is great, tells me my 2.0 60's are terrible to go with my 12.77. I should be 1.77 or so, guess there is more there.
Tom
Re: How do I know if my 60' times are correct for my Car [Re: 72challorange] #324717
05/21/09 04:38 PM
05/21/09 04:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I could be wrong but the too big 60 foot killers are 1 tire spin and 2 driving through the converter.
This means the converter is a little tight for the cam and where it is degreed and the car goes aways before it hits it's power band will act like a sudden increase in power like you just gave it more throttle.
And add that some vacuum actuated 4 barrels come on what to late with improper spring tuning and sometimes diaphram leaks and other problems.
Re: How do I know if my 60' times are correct for my Car [Re: Dodgem] #324718
05/21/09 04:40 PM
05/21/09 04:40 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: How do I know if my 60' times are correct for my Car [Re: 72challorange] #324719
05/21/09 04:55 PM
05/21/09 04:55 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Tom
wallace calc says assuning slicks
Mopar Performance
Re: How do I know if my 60' times are correct for my Car [Re: moparniac] #324720
05/21/09 06:06 PM
05/21/09 06:06 PM
Renton Washington
Triple Threat Offline
Renton Washington
My car runs 12.50's typically and 60's between 1.67 and 1.70.
Best ET was 12.37@106 with a 1.67 60 foot, so yes, you are leaving some ET on the table with what you have now, but you aren't terribly far off.
And according to the Wallace Calculator, my car 60's too fast for the ET it runs. I guess I'm an over achiever.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: How do I know if my 60' times are correct for my Car [Re: sixpackgut] #324721
05/21/09 07:38 PM
05/21/09 07:38 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
http://www.wallaceracing.com/calc60ft.php
Thanks sixpac! It was almost dead on for my car!
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: How do I know if my 60' times are correct for my Car [Re: 67HEMI] #324722
05/21/09 07:40 PM
05/21/09 07:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mine, too, surprisingly...
Re: How do I know if my 60' times are correct for my Car [Re: BradH] #324723
05/21/09 09:00 PM
05/21/09 09:00 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
mines off...... saying 1.48. im switching to sB torsion bars to see if that helps from by .960's
Mopar Performance
Re: How do I know if my 60' times are correct for my Car [Re: sixpackgut] #324724
05/21/09 09:26 PM
05/21/09 09:26 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
With my old no buck 440 and my 10" TA converter in the truck it's best 60 ft. was a 1.595, on a 12.19 et. Dave
Re: How do I know if my 60' times are correct for my Car [Re: quickd100] #324725
05/21/09 09:30 PM
05/21/09 09:30 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
MAN! my stuff must really be outa whack,my 9.50 should be a 1.32,im in the high 1.37 range
Re: How do I know if my 60' times are correct for my Car [Re: bonefish] #324726
05/21/09 09:44 PM
05/21/09 09:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I must be an over achiever too mine 60's 1.34-1.33 and it say's it should be a 1.39.
Re: How do I know if my 60' times are correct for my Car [Re: moparniac] #324727
05/21/09 10:11 PM
05/21/09 10:11 PM
BradH Offline
BradH  Offline
That's a step in the right direction, but you're probably not going to drop a tenth in the 60 just by swapping t-bars. Better plan to spend some time at the track tuning the whole chassis w/ that new combination.
Re: How do I know if my 60' times are correct for my Car [Re: BradH] #324728
05/21/09 10:52 PM
05/21/09 10:52 PM
louisiana
71440dart Offline
71440dart  Offline
louisiana
well i knew it was off, but not this far off, 11.23 with a 1.67 60', says it should be 1.53, and its not too consistant either, any ideas,i have another converter to replace the coan in there now.
71 dodge dart race car,440/727 best so far: 11.23 @119 74 plymoth duster, 408SB/727
