Re: What's the best header gasket material?
[Re: dustyhof]
#324121
05/21/09 12:54 AM
05/21/09 12:54 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I've always used regular Mr Gasket header gaskets with Ultra Copper both sides, and have never had a leak on any vehicle. Don't ask me why, but I just bought some fancy aluminum header gaskets for my Jensen's headers... we can all have a good laugh if they leak! (at my expense, of course! )
CrAzYMoPaRGuY
[Re: dustyhof]
#324122
05/21/09 02:34 AM
05/21/09 02:34 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
I have blown out several sets of the Mr Gasket Ultra seals so far No more of them for me now The graphite coated ones worked okay as well as the regular white Mr Gasket ones I thank the key to making them live is to make sure the sealing surface is perfectly flat on all four sides and retighten them after warming them up for several cycles I haven't tried any of the other high tech ones yet except on a blown hemi motor
[Re: rebel]
#324126
05/21/09 06:51 AM
05/21/09 06:51 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I really like the Percy's aluminum gaskets, they seal great and are reusable.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: 440Laser]
#324128
05/21/09 08:07 AM
05/21/09 08:07 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
[Re: dustyhof]
#324129
05/21/09 08:45 AM
05/21/09 08:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
In the fuel & exhaust lab I use to make gaskets out of a product called Graffoil, graphite over a stainless mesh, very good but hard to cut. It would allow the flange to slide as they expanded and contracted (which happens to all headers/tubes)
[Re: 74DusterP457]
#324131
05/21/09 09:27 AM
05/21/09 09:27 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
WE run Mr Gasket Ultras.Ive reused them even.Only blew out 1 and that was after 5 years and a bolt came loose.They seal unless you have a warped flange.Rocky
Chrysler Firepower
[Re: DJVCuda]
#324137
05/21/09 03:40 PM
05/21/09 03:40 PM
I used, reused, reused some more Cometic MLS gaskets. They finally blew out (steel remained, the filler between didn't) after a bolt fell out of the exhaust flange. I use copper gaskets on the collectors.
