transmission pump ? #323844
05/20/09 07:36 PM
05/20/09 07:36 PM
Newark, OH
springers340dart Offline OP
Newark, OH
for some reason i'm not getting any flow through the cooler, with car idling in neutral i can take off both lines and no fluid is pumping out? but still goes in gears just fine. shouldn't fluid be pumpin out?
Re: transmission pump ? [Re: springers340dart] #323845
05/20/09 08:09 PM
05/20/09 08:09 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Yup, it should be pumping fluid, try removing your lines at transmission just to see if you have a line kinked under your blanket.
Re: transmission pump ? [Re: wheelsup68dart] #323846
05/20/09 08:37 PM
05/20/09 08:37 PM
CT
turbocolt2.4L Offline
CT
ave you chamnged anything lately you should get at least 1 quart in 20 seconds from the return line (rear)if not i would pull both lines off and blow compressed air in cooler to see if its clogged if not could be VB related...
