Pics of Dominator under Shaker #323840
05/20/09 06:35 PM
05/20/09 06:35 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
The other day, someone asked for pics of my Shaker setup on top of the Indy intake and Dominator. Sorry for the delay, but here they are. I know my fabrication skills suck; I wish it looked better, but the ugly parts are hidden and the setup works fine.
Master, again and still
Re: Pics of Dominator under Shaker [Re: DaveRS23] #323841
05/20/09 06:49 PM
05/20/09 06:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Hey as long as it works, right. The base I can totally understand because you had to chop two completely different pieces together, but why does the lid look like you left it on the frying pan a little too long?
Re: Pics of Dominator under Shaker [Re: DaytonaTurbo] #323842
05/20/09 07:07 PM
05/20/09 07:07 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I had to make the air cleaner lid taller in the center so that there was enough clearance to the top of the carb. I used fiberglass mat to make it, in case you hadn't already guessed. And believe it or not, this was my third try. The first two were so bad that the Shaker bubble wouldn't cover the ugly.
