A-body steering column collapsed. How to repin?
#323486
05/20/09 11:00 AM
05/20/09 11:00 AM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
My column is collapsed. I pulled it back to the original position ( indicated by a black mark probably put on at the factory ). I pulled the inner shaft out far enough and could see a recessed grove in the shaft. Should I put it back in the original position and say repin it with some small aluminum shear stock? I would think that would be strong enough to hold everything in place, yet shear in the event of an accident. Please advise.
Thanks, Gary
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: A-body steering column collapsed. How to repin?
[Re: twister360]
#323487
05/20/09 11:28 AM
05/20/09 11:28 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
original pins were plastic, so I don't think aluminium won't hold the position BUT, I think is better try to get PLASTIC pins back to better break in in case of emergency, like originally was.
[Re: NachoRT74]
#323488
05/20/09 11:34 AM
05/20/09 11:34 AM
twister360
Houma, Louisiana
Any idea where I could get plastic pins?
[Re: twister360]
#323489
05/20/09 11:41 AM
05/20/09 11:41 AM
NachoRT74
Valencia, España
not really, hehe, sorry. I'm not in USA to know if they are available maybe you can use one of those plastic rivest used on some parts of modern cars ? and then melt down the ends to a propper fitment. just an idea. Unless somebody sells liquid plastic
[Re: twister360]
#323490
05/20/09 12:59 PM
05/20/09 12:59 PM
Posts: 1,069 Washington State
70Duster440
Washington State
Try a well stocked hardware store with drawers. You should be able to find small nylon screws that will do for pins.
[Re: JulesdaWiperman]
#323497
05/21/09 07:08 AM
05/21/09 07:08 AM
twister360
Houma, Louisiana
Sounds like my solution will work. I am going to assemble the column and install it in my Duster today.
Thanks Jules
