440 distributor drive gear slot position? #323419
05/20/09 09:00 AM
05/20/09 09:00 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
At TDC should the slot for the distributor gear run parallel with the crank and rotor point to #1 cylinder?
Re: 440 distributor drive gear slot position? [Re: 74RR] #323420
05/20/09 09:58 AM
05/20/09 09:58 AM
Ya but you don't HAVE to
The only reason that there are prescribed ways of installing distro's is:
so the assembly line folks can do it all over again
so the plug wires and vacuum advance "sit" right
so a tuneup mechanic "sees" what he expects to see.
Only rigs this isn't true is stuff like V6's where every other pair of cylinders fires closer together
Re: 440 distributor drive gear slot position? #323421
05/20/09 10:10 AM
05/20/09 10:10 AM
Re: 440 distributor drive gear slot position? [Re: RapidRobert] #323422
05/20/09 06:25 PM
05/20/09 06:25 PM
74RR Offline OP
74RR  Offline OP
Thanks for the replys.
