Page 17 of 18 1 2 15 16 17 18
Re: Slow Progress at Zippy Performance [Re: JERICOGTX] #3226422
04/11/24 07:30 AM
04/11/24 07:30 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good work Rich! I'm still here for ya!
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3226459
04/11/24 11:22 AM
04/11/24 11:22 AM
AndyF Offline
AndyF  Offline
Come on Zip, it only took the factory a few hours to build that car!
Re: Slow Progress at Zippy Performance [Re: AndyF] #3226468
04/11/24 12:00 PM
04/11/24 12:00 PM
S.E. Michigan
ZIPPY Online content OP
ZIPPY  Online Content OP
S.E. Michigan
Ha!
If I could build 700 1969 plymouths per day, you bet I would.....
https://youtu.be/MgNOQbK2Yaw
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3226535
04/11/24 05:58 PM
04/11/24 05:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I asked my buddy who built his wide body Jaguar XKE how much labor he had invested. He said if he paid himself $50/hr it would be $750,000. So don't feel bad. Just keep at it.
Doug
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3226537
04/11/24 06:13 PM
04/11/24 06:13 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Said it before , you are doing an amazing job with this . Keep at it . Gary
Re: Slow Progress at Zippy Performance [Re: dvw] #3226538
04/11/24 06:13 PM
04/11/24 06:13 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Fun video
2011 Drag Pak Challenger
Re: Slow Progress at Zippy Performance [Re: rickseeman] #3226707
04/12/24 11:22 AM
04/12/24 11:22 AM
S.E. Michigan
S.E. Michigan
Appreciate the encouragement all, thanks.
Originally Posted by rickseeman
Fun video
He's a fantastic resource for the production side of things and seems to know every little detail.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3226795
04/12/24 10:41 PM
04/12/24 10:41 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted by ZIPPY
Had a productive couple days.
Final prep and spi epoxy Saturday, went back Sunday, seam sealed everything I could, then Summit Hot Rod black.
Rich, presuming two things I have a favor to ask. The top pic shows what I presume to be the rear shackle upper mounting tube in the frame, and presuming it is the same diameter inside and outside as an A-body would it be possible for you to get me those two dimensions of that tube. I need to get some more tube for my car to redo a mistake we made a couple decades ago before we do drag week in my Demon.
Thank you.
eBay-cdwmotorsports
Re: Slow Progress at Zippy Performance [Re: dvw] #3226835
04/13/24 09:46 AM
04/13/24 09:46 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Doug
Clarahan's Jag is an awesome build.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Slow Progress at Zippy Performance [Re: cdwmotorsports] #3227374
04/16/24 07:03 AM
04/16/24 07:03 AM
S.E. Michigan
S.E. Michigan
Thank you.
Sorry CD, the suspension has been back together for weeks, now.
The cluster of posts was just a catch up since I'd taken a hiatus from posting about the project on the boards.
I've never owned an A body....but Supposedly slant 6 and v/8 A bodies were different sizes but the bushing sellers don't list them that way.
The B bodies are supposed to be only one size, A bodies could actually be the smaller or the larger.
Here are a couple links to help you and illustrate. Good luck.
https://www.manciniracing.com/rearsprinsha.html
https://www.forabodiesonly.com/mopar/threads/help-with-leaf-shackle-bushings.367570/
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3233125
05/16/24 10:28 AM
05/16/24 10:28 AM
S.E. Michigan
S.E. Michigan
It's finally running again after a 4 year hiatus. Sure felt good to hear it fire up again!
That's the second time it sat for 4 years.
Because it sat so long, Decided to make sure the oil pump was primed, so I pulled the distributor and intermediate shaft.
The bottom of the bronze gear is the part that’s always bothered me, more than the teeth, as the bottom always wears the fastest. The teeth have always lasted quite awhile.
50 turns of a speed handle was what it took to prime the oil pump, not bad at all for sitting so long, 70psi shown with the speed handle, 80psi running cold.
I think I have vr1 20w50 in it but it’s been 4 years/might be something else but I doubt it.
A Few things went wrong. Secondary needle and seat was stuck bad, got a nice geyser of fuel out the rear bowl vent at first. Freed that up and of course the float level needed to be set again, had to mess with it a bit.
To do the bodywork and get the whole door jambs and all painted I had to remove a lot of underdash wiring and so on to get the dash out of the way, which made a unique mess all it’s own, so the fuel pump and msd are temporarily hooked up
to wiring which had turned into spaghetti really quick when I removed about 2/3 of it, but had to leave the rest of it in place to make sure it'd still run....this is an example of horrible sentence structure.
There aren’t any gauges hooked up at all, other than an oil pressure gauge laying on top of the engine for now.
With it running it'll be alot easier to move the car around to make it easier/safer to re-install the door glass (I'm not willing to risk banging the door on a hoist post so this was a step I needed to take),
and do most of the other work. Also with it running again soon I'll have the opportunity to fix the leaking hoist ram that has driven me bonkers for a couple years......
It was good to hear the little 451 again and get a few Gearhead Feels happening. It's been a good engine for me and it taught me a thing or twelve.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3233126
05/16/24 10:41 AM
05/16/24 10:41 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Had to feel good to hear it sound off! Love that car!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Slow Progress at Zippy Performance [Re: an8sec70cuda] #3233945
05/20/24 01:40 PM
05/20/24 01:40 PM
S.E. Michigan
S.E. Michigan
Thanks for following along this whole time, Chip!
With a little luck, maybe I'll get it out in the sun today for a few pics and to do some shop cleaning/badly needed and hoist repair.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3233971
05/20/24 03:30 PM
05/20/24 03:30 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
When does the HEMI go in?
69 GTX 68 Road Runner
Re: Slow Progress at Zippy Performance [Re: JERICOGTX] #3234005
05/20/24 05:59 PM
05/20/24 05:59 PM
S.E. Michigan
S.E. Michigan
Not 100% sure when.
Probably not too long, but not soon enough laugh
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3234039
05/20/24 10:32 PM
05/20/24 10:32 PM
S.E. Michigan
S.E. Michigan
Today was the first time seeing the whole exterior in full daylight.
I can't lie about the gearhead emotions involved, but they're hard to put into words. Maybe the car can do the talking for a minute.
gtxfirsttimeoutside1.jpggtxfirsttimeoutside2.jpggtxfirsttimeoutside3.jpggtxfirsttimeoutside4.jpg
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3234041
05/20/24 10:37 PM
05/20/24 10:37 PM
S.E. Michigan
S.E. Michigan
That leaker has driven me crazy for a couple years. I didn't want to monkey with anything oily while trying to do bodywork at the same time.
Got that rascal out of there finally.
I'm so looking forward to fixing it, getting the shop in better order and using the hoist to catch up on some daily driver maintenance.
Washed the floor for at least an hour, but I think about a 4 hour effort is going to be needed.
Rich H.
Esse Quam Videri
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3234068
05/21/24 06:11 AM
05/21/24 06:11 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Looking fantastic Rich!
Re: Slow Progress at Zippy Performance [Re: STEFF] #3234070
05/21/24 06:24 AM
05/21/24 06:24 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Looking good Rich!!! Keep plugging along. I just assumed you had the old motor out but, I can see it being a moral booster by having the old motor run.
Re: Slow Progress at Zippy Performance [Re: ZIPPY] #3234162
05/21/24 07:48 PM
05/21/24 07:48 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Definitely seeing outside is a game changer , different light & all . Great work , Gary
