Page 4 of 8 1 2 3 4 5 6 7 8
Re: progress on the race truck project [Re: Mopar Ron] #32332
01/11/07 09:58 PM
01/11/07 09:58 PM
moparx Offline
moparx  Offline
looks good ! how much clearance to the roof are you going with ?
Re: progress on the race truck project [Re: moparx] #32333
01/11/07 10:02 PM
01/11/07 10:02 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
there is about 1/2" at the back bar to the back of the cab and at the top there is around 1 full inch from the top of the bar to cab and the bar should end up about 6" over my head. Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32334
01/11/07 10:17 PM
01/11/07 10:17 PM
moparx Offline
moparx  Offline
thanks ron. hopefully, in the next few weeks, i will be able to start the cage for the humpback. i was thinking about roughly the same distance from the roof[ 1" or so].
by the way, did i ever mention you do good work ?[and FAST too !]
Re: progress on the race truck project [Re: Mopar Ron] #32335
01/12/07 12:24 AM
01/12/07 12:24 AM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
Thanks for the continued updates Ron.
How do you notch your tubing? What tooling are you using?
Mike Bynum
Re: progress on the race truck project [Re: dodgedartgt] #32336
01/12/07 12:42 AM
01/12/07 12:42 AM
Mike Bynum
I don't have a notcher I'm doing it the old fashoned way "grind and fit,grind and fit"
it takes a little while but it's not to bad Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32337
01/12/07 12:49 PM
01/12/07 12:49 PM
i noticed your adding a lot of braces. this, i think, is a good thing. how much is it gonna weigh when your done? do you think its possible the get as much strength as your getting useing a lighter material? im not trying to say anything bad, on the contrary it looks great, im just wondering if it could be as strong with less weight.
Re: progress on the race truck project #32338
01/12/07 02:30 PM
01/12/07 02:30 PM
I am not sure what it will weigh my guess is around 2600#-2700#, the front fenders are fiberglass and the bed will be light and have fiberglass fenders also.
I only want to run between 10.0-10.60 range and I am putting in a 493 stroker with eddy heads and I figure I will only need around 550hp to run those times. and I feel that the 493 is going to make more than that so I may have to slow it down some to run where I want to be.
I dont want to go faster than 9.99 because of all the extra stuff that goes with it
I went with 1 3/4 dom instead of 1 5/8 because we had the 1 3/4 dies for the bender and new dies were going to cost $285. chrome moly cost much more and I dont have a tig setup to weld it. so I went the least expencive way.
I just want a 10.0/135mph fun truck Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32339
01/12/07 04:59 PM
01/12/07 04:59 PM
so the big issue was dollars. that i understand completly.
awsome truck BTW.
Re: progress on the race truck project #32340
01/13/07 12:05 AM
01/13/07 12:05 AM
I fitted the cab back together and checked for rollcage clearence it is great, I can just get my fingers between the bar and the top of the cab.
I added the pieces of metal to the area where I am making the cab 3" longer.
I made the front bars and removed the dash to fit them.
man is it hard to make 2 bars alike but I got it done and welded in. I also made the bar for across the front but didn't get a picture of it.
so here are the latest pics of the cage Ron...
here is with some tape over the cutout area
Re: progress on the race truck project [Re: Mopar Ron] #32341
01/13/07 08:07 PM
01/13/07 08:07 PM
here is what i finished up today, I got the upper bar and the bar under the dash welded in and got the door bar in too. Ron..
just ignore the orange bar, it is holding the body together till I finish the chop
Re: progress on the race truck project [Re: Mopar Ron] #32342
01/13/07 08:08 PM
01/13/07 08:08 PM
The Thumb O' Michigan
Fluffy Offline
Automotive STD Guy
Fluffy  Offline
Automotive STD Guy
Man that stuff gets done quick.
Re: progress on the race truck project [Re: Fluffy] #32343
01/15/07 07:36 PM
01/15/07 07:36 PM
thanks, I'm tring
here are the latest pics of the cage.
I have 1 more bar to weld in the lower area
and then paint the cage and put the back of the cab back on.
then the front of the cab, then the rear bars,
then paint the rest of the cage and fit and weld the back of the cab on.
and finish the chop top. Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32344
01/15/07 08:46 PM
01/15/07 08:46 PM
thanks, I'm tring
all thats left is finnishing. right Ron?
its looking excelent.
Re: progress on the race truck project #32345
01/15/07 09:41 PM
01/15/07 09:41 PM
moparx Offline
moparx  Offline
ron, i think YOU invented the saying : "git-er-done !"
GOOD WORK !!!!!!!!!
Re: progress on the race truck project [Re: moparx] #32346
01/15/07 10:12 PM
01/15/07 10:12 PM
GOOD WORK !!!!!!!!!
Thanks but some projects go faster than others.
I started Squattie over 12 years ago and it is still not on the road yet
and I started mt 35 COE car hauler 3 years ago and now it is on the back burner. till after the race truck.
and my radical COE was started like 5 years ago and I dont know when I will be able to get back to it hopefully later this year
I need to get the 65 coronet back here and get it done as it is a for sale car for the $$$$ to finish the other toys. Ron
Re: progress on the race truck project [Re: Mopar Ron] #32347
01/16/07 01:28 PM
01/16/07 01:28 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Man, that is looking good. I like how tight the cage fits the body.
Out of curiosity, what kind of bender do you have? ...and what radius die are you using?
Do you have any detailed pictures of Squattie?
Re: progress on the race truck project [Re: Flipper1938] #32348
01/16/07 02:05 PM
01/16/07 02:05 PM
Man, thsy is looking good. I like how tight the cage fits the body.
the bender is a JD squared it has a 5.5" radius you can check it out here:
http://www.jd2.com/
I don't have many pics of squattie, I didn't think of documenting that build
it is on a dodge D50 chassis and it took very little to mount it on there.it even still has the D50 rearend,
I have a 318/904 in it and it will look like a little firetruck when its done Ron...
Re: progress on the race truck project [Re: Mopar Ron] #32349
01/16/07 02:33 PM
01/16/07 02:33 PM
san diego
JonsGottaDusta Offline
san diego
We will be documenting the build of my squattie truck so you can have all the info you want then. If I can ever get back over there again!!?!?!?
Getting in trouble sucks
Re: progress on the race truck project [Re: JonsGottaDusta] #32350
01/16/07 06:06 PM
01/16/07 06:06 PM
dogdays Offline
dogdays  Offline
WOWOWOW!!!
You have worked out the kinks in your head to be doing it that fast, fer sure!
I just ran the whole 4 pages backtobacktoback and my head is spinning.
Incredible! Ever use a SKIL saw for chopping the top? I saw it once in a mag, didn't know what to think.
Keep'er floored,
R.
Re: progress on the race truck project [Re: dogdays] #32351
01/17/07 02:02 PM
01/17/07 02:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Are you going to weld in the seat brace and belt mounts before you paint?
LOOKS GREAT!!!
