Pipe plug installed in 8 3/4" diff?
#3233403
05/17/24 06:48 PM
05/17/24 06:48 PM
Posts: 32 Pennsylvania
19_Dart_68
Pennsylvania
Does anyone know why this pipe plug may have been installed in this 742 case? The diff was rebuilt with a Detroit Locker and 3.91 gears at some point.
68 Dart - 440 Swap in Progress...please stand by
Re: Pipe plug installed in 8 3/4" diff?
[Re: 19_Dart_68]
#3233405
05/17/24 06:57 PM
05/17/24 06:57 PM
Posts: 5,938 ohio
ruderunner
ohio
Looks like it would raise the fluid level a fair bit.
Angry white pureblood male
[Re: TJP]
#3233535
05/18/24 12:51 PM
05/18/24 12:51 PM
Posts: 19,609 north of coder
moparx
temp gauge ?? most electric temperature gauges i have seen use 1/8" pipe threads for the sender. that plug looks like maybe 3/8 pipe ? maybe the sender was too close to the pinion shaft, so a bigger pipe thread was used to move the sender away [more clearance] by using a reducer bushing ? just tossing this out there, ASSuming an electric gauge being used instead of a mechanical one............
[Re: 19_Dart_68]
#3233796
05/19/24 06:24 PM
05/19/24 06:24 PM
Posts: 3,098 Michigan
A727Tflite
Does anyone know why this pipe plug may have been installed in this 742 case? The diff was rebuilt with a Detroit Locker and 3.91 gears at some point. What’s the casting number and date on the housing.
[Re: 340Cuda]
#3233820
05/19/24 08:35 PM
05/19/24 08:35 PM
Posts: 1,848 South Bend
John Brown
South Bend
I thought maybe an RPM sensor that was triggered by the pinon teeth but is it too far forward for that? Could the splines trigger a sensor?
[Re: John Brown]
#3233846
05/19/24 11:10 PM
05/19/24 11:10 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
Don't ask how, but I've seen the square twisted right off on the fill plug and then you can't get it out without welding.
Maybe that happened in it's past life, the new fill plug got installed, and later it was repaired properly?
Aux oil cooler somehow? Can't say temp sender because the probe would barely get a proper reading there.
Mo' Farts
Moderated by "tbagger".
[Re: John Brown]
#3233933
05/20/24 01:05 PM
05/20/24 01:05 PM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I thought maybe an RPM sensor that was triggered by the pinon teeth but is it too far forward for that? Could the splines trigger a sensor? Probably if they are exposed in that area.
[Re: autoxcuda]
#3233934
05/20/24 01:08 PM
05/20/24 01:08 PM
340Cuda
Tulsa, Oklahoma
Nascar 8 3/4 used Detroit Lockers.
Maybe a port for a rear end oil cooler. I could see that being a return line with the supply line off the axle housing.
[Re: autoxcuda]
#3233972
05/20/24 03:45 PM
05/20/24 03:45 PM
Posts: 6,017 Salem
Grizzly
Salem
Yeah, I mentioned that above, but: too much crap to fall off of a car with little gain unless it's a balls to the wall road racing effort. If so, better off with the Aluminum 8.75 assembly as it would dissipate heat just as well, is lighter, and more reliable with no pump, lines, or heat exchanger to get knocked off the car.
Mo' Farts
[Re: autoxcuda]
#3234029
05/20/24 09:16 PM
05/20/24 09:16 PM
A727Tflite
Maybe a port for a rear end oil cooler. Winner !
