Bad luck with 440source starters #3232652
05/13/24 09:40 PM
05/13/24 09:40 PM
Kirkland, Washington
Pacnorthcuda Online boogie OP
Pacnorthcuda  Online Boogie OP
I’ve had good luck with their heads and water pump housing. Six weeks ago I installed their $100 starter. At a car show the selonoid wouldn’t disengage and the car kept cranking after key removed. Sent it back on my $20 and 440source delivered a new one today. Bench tested OK. Installed, send power to it and nothing, but there is a power draw. Bench tested and the unit (testing selonoid only) draws power but bendix doesn’t throw gear.
I have ZERO confidence in this POS. I bought an AC Delco from Rockauto ($103).. sorry Brandon…I HAVE ZERO confidence in your starters.
Re: Bad luck with 440source starters [Re: Pacnorthcuda] #3232667
05/13/24 11:18 PM
05/13/24 11:18 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have heard that story before from others.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Bad luck with 440source starters [Re: Pacnorthcuda] #3233046
05/15/24 07:52 PM
05/15/24 07:52 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Definitely a part I'd be buying from the local part store. Considering inflation as of lately, a early failure of $100 part would have it as a core for the next one for me.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Bad luck with 440source starters [Re: A39Coronet] #3233078
05/15/24 10:28 PM
05/15/24 10:28 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
When buying a "mini" starter you need to stay with the original DENSO brand starters and not the Chinese knock-offs. Mancini carries the Denso starters that work and will last longer than your engine will twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Bad luck with 440source starters [Re: fourgearsavoy] #3233146
05/16/24 12:00 PM
05/16/24 12:00 PM
moparx Offline
moparx  Offline
Gus beer
another reason to get one from the bone yard [if possible] and replace the contactor set.
beer
Re: Bad luck with 440source starters [Re: moparx] #3233163
05/16/24 01:03 PM
05/16/24 01:03 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Used Dakota or Durango starter and fresh contacts make for a good starter on the cheap. beer
I have a relative who bought an expensive MP mini starter years ago, and it sure looks like an OEM Dakota unit only for a lot more money.
