VEPR heads? #3232643
05/13/24 08:47 PM
05/13/24 08:47 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Seeing these on the FB mopar groups, anyone have any more info on these? 370 if real seems pretty stout.
Re: VEPR heads? [Re: Uberpube] #3232666
05/13/24 11:08 PM
05/13/24 11:08 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I saw them too. Never heard of them so proceed with caution.
Re: VEPR heads? [Re: Uberpube] #3232676
05/14/24 01:46 AM
05/14/24 01:46 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Well ported 2.300 intake on a B1 is typically pushing 400 cfm, what's the port window on this head? S/F....Ken M
Re: VEPR heads? [Re: EchoSixMike] #3232718
05/14/24 11:16 AM
05/14/24 11:16 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I saw that on FB. I asked them what the offset was on the intake rocker but haven't heard back yet.
Re: VEPR heads? [Re: cl440] #3232722
05/14/24 11:32 AM
05/14/24 11:32 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Here’s my guess……
It starts out as a Steven Sun produced TF240/ 270 copy, that someone has developed their own cnc porting program for.
I’m thinking it’s the same casting this:
https://m.youtube.com/watch?v=5Cdj8GNCC80
Re: VEPR heads? [Re: fast68plymouth] #3232740
05/14/24 12:19 PM
05/14/24 12:19 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Oh, boy, another Chinese R&D (Rob & Duplicate) cylinder head...
Who puts a 2.30" intake valve in a BBM head that doesn't also move the valves away from the cylinder wall? Standard shelf pistons usually factor in a max of a 2.25" valve pocket... makes me wonder how tuned into the Mopar market the person doing the head porting, etc. is.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: VEPR heads? [Re: Brad_Haak] #3232776
05/14/24 02:23 PM
05/14/24 02:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Pic from the Steven Sun instagram page:
RPM copy in the foreground, TF240 copy behind it
Re: VEPR heads? [Re: fast68plymouth] #3232781
05/14/24 02:32 PM
05/14/24 02:32 PM
NH, USA
toddinNH Offline
Egghead
toddinNH  Offline
Egghead
NH, USA
Pure coincidence. /s
Re: VEPR heads? [Re: fast68plymouth] #3232790
05/14/24 03:11 PM
05/14/24 03:11 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Here’s my guess……
You are probably correct. they told me they recommend the Harland Sharp S70016KE which is designed for the Trick Flow 240/270 head
Re: VEPR heads? [Re: toddinNH] #3232792
05/14/24 03:16 PM
05/14/24 03:16 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
STOP POTATO HATE!
Re: VEPR heads? [Re: Mr PotatoHead] #3232794
05/14/24 03:24 PM
05/14/24 03:24 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Not hard to look them up. Seems they have a lot invested in there operation.
Sad fact is they may do good work and have good products (or not) but my point is its a shame we dont really have much in the USA as far as foundry facilities. And just as sad china can do a few things better since were so restricted.
Openly says all there castings come from china, they do all the machine work and in this kit vid. A good bit of name brand us products other then the castings.
Who knows.
STOP POTATO HATE!
Re: VEPR heads? [Re: Mr PotatoHead] #3232814
05/14/24 04:55 PM
05/14/24 04:55 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
IMO, they are simply a solution for a problem that doesn't exist
Re: VEPR heads? [Re: Uberpube] #3232816
05/14/24 05:00 PM
05/14/24 05:00 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Straub Technologies is 19 minutes from me. I may have to check them out. There are a few dissatisfied customers on YB but I take that with a grain of salt.
They are at the same address as a company that makes distributor gears (both brass and melonized) and they are in the same industrial area as Nickels Performance Distributors which has been bought by Summit Racing.
Re: VEPR heads? [Re: Brad_Haak] #3232913
05/15/24 09:41 AM
05/15/24 09:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There is a problem for some ... COST ... the solution is to steal someone else's technology, have it copied outside the country in a place that doesn't care about U.S. patents, and sell it for less.
Re: VEPR heads? [Re: JohnRR] #3232994
05/15/24 02:42 PM
05/15/24 02:42 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Not "the problem" I was inferring, but I certainly understand the reason for your comments...
Funny thing is by the time you pay for the bare castings (still haven't seen a price for those particular ones), pay for the $1500 CNC work (what I saw listed on the vendor's website), pay for quality parts to complete the heads, etc., how much would you really be saving vs buying a set of TF 270s from the original manufacturer?
I'll be amused if this new "bolt on" head actually won't "bolt on" cuz their choice of a 2.30" intake valve makes them unsuitable for 90%+ of the pistons used in the type of build for which people use this style of head.
Re: VEPR heads? [Re: Brad_Haak] #3233021
05/15/24 06:08 PM
05/15/24 06:08 PM
GomangoCuda Offline
GomangoCuda  Offline
Quote
Two very good points. Yep probably not interested.
Re: VEPR heads? [Re: GomangoCuda] #3233039
05/15/24 07:27 PM
05/15/24 07:27 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Peak flow may not be the critical end all number for any cylinder head, and 370 is fairly decent overall..............for a small block. For a 2.30 valve head targeted for a big block application, it's weak. There are 23* small block chevy heads with way less valve that move more than that on their minuscule bore center.
Re: VEPR heads? [Re: jim sciortino] #3233048
05/15/24 07:57 PM
05/15/24 07:57 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The porter for Straub certainly doesn't appear to be one of the best in the business.
https://www.yellowbullet.com/threads/cylinder-head-show-and-tell.129971/page-276
Chris Straub posted some result on some GM heads in this thread, that seemed very underwhelming. Maybe they make power? No one really knows.
Alan Jones
Re: VEPR heads? [Re: jim sciortino] #3233071
05/15/24 09:52 PM
05/15/24 09:52 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
On the Chrysler list on Stan Weiss;s site , 350-375 seems to be the ceiling for most B engine heads, and that number would also be decent for a non offset valvetrain head. .
But after reading all the drama on Yellow Bullet, I'm not going to be the guinea pig with these, I'm ready to buy b1's since 370 seems to be the basement on B1's. Anyone know if Koffell ever returns emails?.
Re: VEPR heads? [Re: Uberpube] #3233107
05/16/24 06:56 AM
05/16/24 06:56 AM
JohnRR Offline
JohnRR  Offline
Member reknapp52 just listed a pair in the race parts for sale section for 3k with rocker shafts and stands , don't know if they are a good deal or ? .
