Re: 904 converter recommendation?
[Re: J_BODY]
#3232398
05/12/24 09:19 PM
05/12/24 09:19 PM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
I have ATI, Coan, PTC, Midwest, and TCI. The only one I am not wild about is the TCI, but I bought it cheap and used, so there's that.
I had PTC repair the ATI, and service was great.
As Jay said, you're going to get lots of answers, all different.
[Re: slantzilla]
#3232418
05/12/24 10:08 PM
05/12/24 10:08 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends. No info on your combination or is it a race car with tags or a street car that goes to the track occasionally.
Coan is close to you. He does some really nice stuff.
Budget? A good race piece will be close to or over 4 figures. An old shelf 3500 10", not so much.
[Re: CMcAllister]
#3232452
05/13/24 06:43 AM
05/13/24 06:43 AM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
68 Cuda 360 stock stroke 10.2 compression Cam 241/247 duration at 050, .545 lift, 110 lobe separation / hydraulic Eagle rods Lightweight Ross pistons LD340 intake Holley 800 double pumper Doug’s D-453 headers/2.5 exhaust 3.91 gears 26” tall tires
[Re: Valiant_Showoff]
#3232665
05/13/24 11:05 PM
05/13/24 11:05 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
There's a great local company right here in NEO. Perfect Converter AKA 501 Performance. Myself and many others in the area are using them and they are awesome to work with. Definitely worth calling them and talking about your needs. Talk to Bubba Rafferty or Logan Siegman. They are pretty big sponsors at Dragway 42 and work a lot with B3R racing and many other shops. Tell em Russ recommended you.
[Re: max_maniac]
#3232721
05/14/24 11:19 AM
05/14/24 11:19 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Whoever you choose spend the money and get the A500 style pump gears and use the A500 style converter snout. I have had problems with 904 converter snouts cracking or breaking even the "heavy duty" thicker ones. I have used the A500 style for 6 years no with no trouble.
I have had great luck with turbo action converters but I have never tried anywhere else. I used a Turbo Action 8" 4500 behind my 11:1 360 with edelbrock heads for street and strip use. I use that same converter now with my 418" motor but it flashes much higher behind the 418" motor.
68 Barracuda Formula S 340
[Re: max_maniac]
#3232822
05/14/24 06:05 PM
05/14/24 06:05 PM
Valiant_Showoff
Alliance, Ohio
There's a great local company right here in NEO. Perfect Converter AKA 501 Performance. Myself and many others in the area are using them and they are awesome to work with. Definitely worth calling them and talking about your needs. Talk to Bubba Rafferty or Logan Siegman. They are pretty big sponsors at Dragway 42 and work a lot with B3R racing and many other shops. Tell em Russ recommended you. Talked to 501 today. Sounds like a good option.
[Re: J_BODY]
#3232888
05/15/24 07:24 AM
05/15/24 07:24 AM
Posts: 8,294 fredericksburg,va
cudaman1969
fredericksburg,va
I’m also a “fan” of the A500 pump gear….. both of my 904 trans are equipped with them…… and Lenny knew exactly what I was talking about and had the drive hubs in stock for building my converter. I assume the converter stub has to be changed for that? What’s the reason to change?
[Re: Leigh]
#3232892
05/15/24 07:57 AM
05/15/24 07:57 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
ATI. They are the only current company that uses all new components. That is not a true statement - most of the converter components today come from sonnex - several companies out there use new converter cores and all new components - However I believe ATI still has the new 8" cores. But most have moved away from the 8" and gone to the 9.5'-10" billet body which makes for a better converter
[Re: cudaman1969]
#3232931
05/15/24 10:55 AM
05/15/24 10:55 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I’m also a “fan” of the A500 pump gear….. both of my 904 trans are equipped with them…… and Lenny knew exactly what I was talking about and had the drive hubs in stock for building my converter. I assume the converter stub has to be changed for that? What’s the reason to change? Yes that is the reason for the change, the snouts with the "flats" like the A500 pump gear uses do not crack in the slots (they don't have them) like the older snouts. Our experience is even the strongest chrome moly snouts will crack using the old style with the slots for the pump drive.
[Re: 340Cuda]
#3233050
05/15/24 08:05 PM
05/15/24 08:05 PM
Posts: 6,146 Melbourne , Australia
LA360
I’m also a “fan” of the A500 pump gear….. both of my 904 trans are equipped with them…… and Lenny knew exactly what I was talking about and had the drive hubs in stock for building my converter. I assume the converter stub has to be changed for that? What’s the reason to change? Yes that is the reason for the change, the snouts with the "flats" like the A500 pump gear uses do not crack in the slots (they don't have them) like the older snouts. Our experience is even the strongest chrome moly snouts will crack using the old style with the slots for the pump drive. In Australia, we machine the pump to take a Borg Warner 35 pump bush, and run a stepped converter snout. No cracking
Alan Jones
