Engine diaper
#3232221
05/11/24 06:33 PM
05/11/24 06:33 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I am getting ready to run some NDRL races and a somewhat local to me track and both of them require all cars to run a lower engine containment device. I bought a Russler II, sportsman diaper. It looks real nice, but my question is, how much heat will it take before it melts? I have an E body, RB w/ TTI step headers, stock K frame and a Milodon Super Stock pan (w/ the steering link thru the sump). The diaper fits good, real snug, but each side has a header tube that has very little if any clearance between the block and header tube. Is this a valid concern, or will it work? I'm thinking about trying to fabricate a simple heat shield to clamp to the header tube, but not sure it will be worth the hassle. Any suggestions?
Brian
Re: Engine diaper
[Re: '72CudaRacer]
#3232237
05/11/24 09:12 PM
05/11/24 09:12 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Real concern in my opinion. Mine has special high heat material where it got close to the header and even with that I made tight fitting aluminum shields to press the diaper closer to the block and away from the header.
Re: Engine diaper
[Re: dvw]
#3232243
05/11/24 10:26 PM
05/11/24 10:26 PM
'72CudaRacer
Mooresburg, Tn
It needs to be about 1 1/2". Doug 1 1/2" away from the header tube? I have maybe 3/4" in some places. I'm not sure even with a heat shield it won't melt/burn. Brian
Re: Engine diaper
[Re: old_racer]
#3232244
05/11/24 10:30 PM
05/11/24 10:30 PM
'72CudaRacer
Mooresburg, Tn
when I bought my Russler II I test fit and seen where it was close to the header in spots , I called him and he told me to mark the diaper with a marker where it was close and send it back , he then sewed on some reflective material in tho's spots. great guy. I'm thinking that may be the best solution. I have a few weeks to get it back and forth. And yes, Russ is very easy to work with. We all need more vendors like him. Brian
Re: Engine diaper
[Re: '72CudaRacer]
#3232245
05/11/24 10:34 PM
05/11/24 10:34 PM
'72CudaRacer
Mooresburg, Tn
It needs to be about 1 1/2". Doug 1 1/2" away from the header tube? I have maybe 3/4" in some places. I'm not sure even with a heat shield it won't melt/burn. Brian Also, anyone know where to purchase the aluminized sheets of heat shield? I have some small tube style heat shield that goes around small hoses or wires, but not sure where to get a small sheet of it. Thanks, Brian
Re: Engine diaper
[Re: SportF]
#3232280
05/12/24 10:00 AM
05/12/24 10:00 AM
Posts: 2,521 PA
moparacer
PA
wrap the header in the close areas. With the wrap on, the material can touch it and be ok. You may have to wrap several tubes to do this, but it works. As much as I despise header wrap, I agree its the best solution in this case.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Engine diaper
[Re: old_racer]
#3232400
05/12/24 09:21 PM
05/12/24 09:21 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
when I bought my Russler II I test fit and seen where it was close to the header in spots , I called him and he told me to mark the diaper with a marker where it was close and send it back , he then sewed on some reflective material in tho's spots. great guy. ^THIS!! personally I’d start here, and follow it up with a section of header wrap. Long term solution might involve massaging the header tube. Thanks for giving Russ your business! Not too many guys still have that “help your brethren” mentality like him.
Re: Engine diaper
[Re: J_BODY]
#3232458
05/13/24 07:58 AM
05/13/24 07:58 AM
Posts: 9,865 MI, usa
dvw
MI, usa
when I bought my Russler II I test fit and seen where it was close to the header in spots , I called him and he told me to mark the diaper with a marker where it was close and send it back , he then sewed on some reflective material in tho's spots. great guy. ^THIS!! personally I’d start here, and follow it up with a section of header wrap. Long term solution might involve massaging the header tube. Thanks for giving Russ your business! Not too many guys still have that “help your brethren” mentality like him. Agreed Russ treats people like we all wish all business's would. My diaper from him is on it's 12th year. And yes it's been tested. Even with the drag link hole, not a drop spilled onto the track. Doug
Re: Engine diaper
[Re: moparacer]
#3232459
05/13/24 08:38 AM
05/13/24 08:38 AM
Posts: 40 indianapolis, in
rt1976
indianapolis, in
I have some short sections of wrap in needed areas I keep it secure w/ racing wire
Re: Engine diaper
[Re: rt1976]
#3232851
05/14/24 09:47 PM
05/14/24 09:47 PM
J_BODY
aZLiViN
I have some short sections of wrap in needed areas I keep it secure w/ racing wire I have four oil return lines from my heads to my custom oil pan. Russ put in “shoe lace” eyelets on my diaper build to secure it tightly around that area. Pretty cool when this 80 year old dude in his daily driver 50s Ford long roof stops by to check in on me. Russ is a great individual with a hobby that helps us.
