Re: New 540 build
[Re: Mbrown]
#3232175
05/11/24 11:47 AM
05/11/24 11:47 AM
Posts: 4,691 On the parachute mount
n20mstr
I was really humbled at BES. There was huge billet motors everywhere. They had a 600+ cubic inch small block chevy that was 1200+ hp. It looked like a work of art. Tony and his staff are so friendly and professional. Tony made us feel like we were his most important customer while we were there. I really enjoyed working with them. All the guys there are great , the work speaks for itself . They do all types of engines . They are definitely one of the best out there to deal with . What block did you use for this build ?
....BAD A$$ STREET CAR.....
Re: New 540 build
[Re: Mbrown]
#3232176
05/11/24 11:49 AM
05/11/24 11:49 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How'd you do that? I'm a dummy sometimes. It’s this damn website. Pictures need resized, post sideways or upside down. And guys wonder why this site is losing posts on tech.
Re: New 540 build
[Re: n20mstr]
#3232180
05/11/24 12:09 PM
05/11/24 12:09 PM
Posts: 34 Indiana
Mbrown
Indiana
I was really humbled at BES. There was huge billet motors everywhere. They had a 600+ cubic inch small block chevy that was 1200+ hp. It looked like a work of art. Tony and his staff are so friendly and professional. Tony made us feel like we were his most important customer while we were there. I really enjoyed working with them. All the guys there are great , the work speaks for itself . They do all types of engines . They are definitely one of the best out there to deal with . What block did you use for this build ? I'm embarrassed to say. It's an oem 440 block. Although it is a VERY thick block. Aluminum caps, girdle, ect. I am a little concerned about the life expectancy. Tony thinks we should be OK, being a low rpm deal.
Re: New 540 build
[Re: pittsburghracer]
#3232191
05/11/24 01:10 PM
05/11/24 01:10 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Great job! you were in great hands with Tony.
Looks like Ritchie working on the motor?
Re: New 540 build
[Re: Mbrown]
#3232193
05/11/24 01:14 PM
05/11/24 01:14 PM
n20mstr
I was really humbled at BES. There was huge billet motors everywhere. They had a 600+ cubic inch small block chevy that was 1200+ hp. It looked like a work of art. Tony and his staff are so friendly and professional. Tony made us feel like we were his most important customer while we were there. I really enjoyed working with them. All the guys there are great , the work speaks for itself . They do all types of engines . They are definitely one of the best out there to deal with . What block did you use for this build ? I'm embarrassed to say. It's an oem 440 block. Although it is a VERY thick block. Aluminum caps, girdle, ect. I am a little concerned about the life expectancy. Tony thinks we should be OK, being a low rpm deal. Keep it out of detonation and it probably will live . I have a similar engine with stock caps and so far it has lived
Re: New 540 build
[Re: markz528]
#3232195
05/11/24 01:33 PM
05/11/24 01:33 PM
Posts: 34 Indiana
Mbrown
Indiana
Looks like Ritchie working on the motor? Yes. Rich worked with us most of the day. He did an awesome job.
Re: New 540 build
#3232205
05/11/24 03:56 PM
05/11/24 03:56 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures?
Re: New 540 build
[Re: Cab_Burge]
#3232218
05/11/24 05:16 PM
05/11/24 05:16 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures? Why push a stock block to the moon. Go out and have fun.
Re: New 540 build
[Re: Cab_Burge]
#3232220
05/11/24 06:09 PM
05/11/24 06:09 PM
Posts: 34 Indiana
Mbrown
Indiana
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures? I'm running a Jones solid roller with crower lifter. Springs are 255 on the seat and 660#'s over the nose. I told Rich we were shifting at 6800 before we started, regardless of power curve. It may be flawed thinking on my part, but I believe an oem block has a better chance of living if you don't rev the piss out of it. I sized everything when designing the motor to peak at 65-6600. Heads, cam, intake, headers, ect
Re: New 540 build
[Re: Mbrown]
#3232246
05/11/24 10:34 PM
05/11/24 10:34 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures? I'm running a Jones solid roller with crower lifter. Springs are 255 on the seat and 660#'s over the nose. I told Rich we were shifting at 6800 before we started, regardless of power curve. It may be flawed thinking on my part, but I believe an oem block has a better chance of living if you don't rev the piss out of it. I sized everything when designing the motor to peak at 65-6600. Heads, cam, intake, headers, ect i am solidly behind the path you chose here. Knowing my rpm graph shows actual rpm of the 1/2 shift to be higher than the programmed rpm in rhe electronics activated air shifter, if it were mine i would start by shifting by eye at 6400, 6500 if an air or electric shifter is in use. Add a hundred rpm for the 2/3 shift. From my limited experiance those heads are making about the limit of thier hp capability, and then some.
Re: New 540 build
[Re: gregsdart]
#3232298
05/12/24 11:19 AM
05/12/24 11:19 AM
Posts: 2,521 PA
moparacer
PA
Did you try revving it higher to make sure the motor had reach peak RPM and not started a dip that would go away in another hundred RPM? What type of cam and lifters and valve spring pressures? Why push a stock block to the moon. Go out and have fun. 879 HP on a 440 block might not be a lunar landing....But its definitely in orbit..... I am surprised it managed to make peak HP in the high 6000s range with that 4.5 stroke, small bore and head combo. The Torque was in early as expected. Those must be some killer Victor heads you have there Mbrown!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
