more modern 3 speed wiper motor vs. older 3 speed
#3232123
05/10/24 10:47 PM
05/10/24 10:47 PM
Posts: 2,946 GA
roadrunninMark
GA
I thought there was a thread about someone using a more modern 3 speed wiper motor in place of one of the older / original ones. If there is, I can't find it. I am doing a 2 speed to 3 speed in the 69 roadrunner and I don't need an original looking motor (or the price of such). I need the clearance of the 3 speed for a fresh air intake setup through my 6 barrel hood; the 2 speed won't fit. I also thought a 3 speed from a mid to upper 70's(?) may work if the park is changed? Has anyone used a different/modern 3 speed wiper motor?
Also, is the 3 speed wiper switch the same for a rally and non rally dash?
Re: more modern 3 speed wiper motor vs. older 3 speed
[Re: roadrunninMark]
#3232210
05/11/24 04:21 PM
05/11/24 04:21 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I agree with FastMark....just use a C-body 3-speed wiper motor. I have one on my 70 Road Runner now. I seem to recall I had to take a rat tail file and round out the opposite side of my "crank" (first linkage piece) since the C-body 3-speed motor I got had the park position vs. rounded side of piece where the crank attaches on the opposite side. It's worked perfectly for many years.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#3232681
05/14/24 05:31 AM
05/14/24 05:31 AM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
The motor will. Not the crank arm. Call Bruce Somer. Ns1aar on this board.
#3232911
05/15/24 09:38 AM
05/15/24 09:38 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Appreciate the info.. just ran into an issue with my 6 barrel hood now. Apparently the original style 6 barrel hood scoop is too short. Now I need about a 5inch scoop height vs. the original 3 inch. I have a super victor intake on my Indy heads, which is really tall. I tried a small air cleaner but still too tall. I can use my 2 speed setup though. I have to find a taller scooped hood. Non stock heads , which are taller , and intake , again even taller , so sadly not surprised , you could always lower the engine ???
