Strange question with 383 a bit baffled? #3231242
05/05/24 09:08 PM
05/05/24 09:08 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
68 Monaco, All stock pretty much untouched except for an edelbrock AVS 650. Timing was set at 14 initial, ~20 mechanical, and 18 or so vacuum ported. petronix conversion.
Car backfires through the carb horribly when at low speeds and the secondaries are opened. Adjusted the air valve as tight as possible with little to no help. tried manifold vac. for the VA and disconnecting it completely.
Timing chain was loose enough to be making noise barely touching the cover. It was swapped with an Edelbrock set.
Very little change.
Swapped to a performer 600, better but still bogs / hesitates when the secondaries are opened.
To shorten the story a bit, Also tried a 1850 Holley, better but still hesitates a bit. Increase timing to 20, better, 30 even better, settle on 36 INTIAL 😳. TDC was verified when timing chain was installed as well as damper to timing mark.
Runs awesome at 36 +20M +18 on ported. Timing light was also verified.
Any clues on this one?? confused beer
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231261
05/05/24 10:39 PM
05/05/24 10:39 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
Sounds a lot like my 440 I was having problems with. Finally figured out timing tab is in the wrong spot. With the TDC balancer mark at 6 o'clock I taped the balancer and measured to the 0 degree mark on the tab and turns out it was 23 degrees off from where it should be based on comparing it to other big block timing covers I have. Had to time it with a dial back light but it runs great. Shows 38 degrees initial which in all actuality is only 15 degrees.
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231267
05/05/24 11:34 PM
05/05/24 11:34 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
cam retarded , timing chain off 1 tooth !
Re: Strange question with 383 a bit baffled? [Re: calrobb2000] #3231272
05/06/24 12:18 AM
05/06/24 12:18 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Has got to be one of the two responses so far.
I want my fair share
Re: Strange question with 383 a bit baffled? [Re: SomeCarGuy] #3231284
05/06/24 05:50 AM
05/06/24 05:50 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Compression test? I'm thinking burnt or sticky valve.
Angry white pureblood male
Re: Strange question with 383 a bit baffled? [Re: ruderunner] #3231303
05/06/24 08:57 AM
05/06/24 08:57 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Is the polarity correct on the magnetic pickup? I've seen it retard the timing by as much as 20 degrees on an MSD ignition.
Re: Strange question with 383 a bit baffled? [Re: MarkZ] #3231319
05/06/24 09:39 AM
05/06/24 09:39 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Absolutely have had that problem. Around 2000 or so, many of the MSD's coming out of Mexico were put together by people who were color blind. Got that information direct from MSD rep at Motor State Distributing. Solution was to cut one pair of wires and re-attach them flipped. Previous to doing that, the electronics had the distributor retarding when it should have been advancing. BTDT.
Re: Strange question with 383 a bit baffled? [Re: calrobb2000] #3231437
05/06/24 05:39 PM
05/06/24 05:39 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Originally Posted by calrobb2000
hi
This, if you need 36 degrees initial timing, you're off a tooth. If that's not it you've bent an intake valve when the other chain was failing.
Re: Strange question with 383 a bit baffled? [Re: MarkZ] #3231458
05/06/24 07:28 PM
05/06/24 07:28 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
I have to agree with with everyone on the timing issue, be it ignition of cam. The car belongs to a friend and came to him this way. Running, but would not take a quick WOT without dying, or backfiring through the carb. Through the course of diagnosing the above an erratic squeaking started that he attributed to the belts.
It started to become more noticeable/irritating so he removed the belts and the noise was still there. tracing it to the timing cover he installed a new Edelbrock set.
If he hadn't just put a new chain in it I would say pull the cover again to verify that and suggested doing so. Knowing him well, I am 99.9% sure he installed the chain correctly, but it's possible he missed by a tooth. He has decided to run it as is. whistling
The ignition is a petronix unit and wired correctly.
Myself, I would have to pull the cover to verify and /or keep digging to find the cause wink
I do want to thank all that responded up beer
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231610
05/07/24 06:18 PM
05/07/24 06:18 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If it's a multi keyway timing set, are the right marks lined up? BTDT
Re: Strange question with 383 a bit baffled? [Re: ruderunner] #3231646
05/07/24 09:27 PM
05/07/24 09:27 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
it is and don't know but I'm going to say the answer is likely the valve timing. he's choosing to run it as is shruggy whistling beer
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231656
05/07/24 10:02 PM
05/07/24 10:02 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
It won't fix itself, and has to be taking all the enjoyment out of driving it, which is a bummer. I'd be worried about it quitting in traffic ect., and being in someone's way since it's not going to accelerate smoothly like normal. Who wants to drive around with that on their mind?
Re: Strange question with 383 a bit baffled? [Re: Neil] #3231779
05/08/24 04:24 PM
05/08/24 04:24 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Agreed wink he says it runs fine and he's happy so shruggy whistling
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231836
05/08/24 10:08 PM
05/08/24 10:08 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
talked with him again today and relayed everyone's comments. He said he's going to pull the cover again when he gets time as it is bothering him as well. I'll update if and when he does
Thanks again to all beer
Re: Strange question with 383 a bit baffled? [Re: TJP] #3231852
05/09/24 05:46 AM
05/09/24 05:46 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Let him know the crank key doesn't point straight up. That's what got me.
Re: Strange question with 383 a bit baffled? [Re: ruderunner] #3231861
05/09/24 08:26 AM
05/09/24 08:26 AM
SomeCarGuy Offline
SomeCarGuy  Offline
I had a set one time that had a multi key way that included a circle. It looked like a dot to me. Degreed it and was way off. Then saw the little dot. Used that one and it was dead nuts on.
Re: Strange question with 383 a bit baffled? [Re: SomeCarGuy] #3231920
05/09/24 03:12 PM
05/09/24 03:12 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
he said the the crank keyway was ~ 2:00 which I believe is correct ?
I hate the 3 slot crank gears and their markings 🤬 Easy to get balled up if not paying real close attention twocents
