Re: Callies Iron Hemi Block
[Re: 71birdJ68]
#3229374
04/26/24 08:26 PM
04/26/24 08:26 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Oh yeah, Lifter holes & oil galleys are atrocious and will need much deburring Head dowels are too close together, plan on grinding dowels to fit heads Check threads on every hole, pipe threads will need to be tapped deeper Grind relief in the valley where inside head nuts go for wrench clearance if it's a Hemi #7 exhaust pushrod might need more clearance if it's a Hemi All the .246" dowel pin holes were way too tight Ream dowel holes to .245” If it's a Hemi and you are going to run TTI headers, if you wait to grind for clearance on the block until you get it in the car, I'll go ahead and offer $500 for your car now. And at midnight the night you put it in you will call me to tell me to come and get it. There might have been more, but that's all I can think of.
I did a video on Callies block prep. If you want to see it, I will look up what number it was.
2011 Drag Pak Challenger
[Re: 71birdJ68]
#3229398
04/27/24 12:26 AM
04/27/24 12:26 AM
rickseeman
Stuttgart, Arkansas
I like them. I’m just saying this isn’t the old days. It will take a little time to get it right. Like everything else we buy today. We are building engines with all aftermarket parts. Just take your time and keep your eyes open. You might as well start from the beginning of that series and it will guide you through building a Callies Hemi. Every thing will be fine.
[Re: 71birdJ68]
#3231579
05/07/24 03:17 PM
05/07/24 03:17 PM
Posts: 422 montana
BANDIT
montana
I just picked up a production 1966 block and set of heads, am going to have it baked and peened first, but initially it looks like it will clean up at 0.030. was going to try and find a rotating assembly for it. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: rickseeman]
#3234248
05/22/24 10:56 AM
05/22/24 10:56 AM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
Is it safe to assume the marketer has never, ever heard of these issues, and everything is fine as far as they know?
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3234303
05/22/24 02:59 PM
05/22/24 02:59 PM
rickseeman
Stuttgart, Arkansas
Somebody may have informed them but I'm sure they don't listen. Kinda like when I call them for a crankshaft and they give me a delivery date. If I want to know the delivery date on a Callies crank I go to Wal-Mart and ask the first 6 year old girl I see. She can get closer to the date than they can. If I called them about the block they would probably say their quality control is great. This is the first time we've ever heard of this, blah, blah, blah. Unlike calling Indy when Russ would just tell you he's the smartest guy in the world and you're just a dumba**. Energy and Callies should watch my build video if they want an eye opener.
[Re: BANDIT]
#3234448
05/23/24 09:51 AM
05/23/24 09:51 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
I just picked up a production 1966 block and set of heads, am going to have it baked and peened first, but initially it looks like it will clean up at 0.030. was going to try and find a rotating assembly for it. Jim. Shouldn't be hard to find one , you don't need to buy old used up parts for a rotating assembly.
[Re: rickseeman]
#3234490
05/23/24 12:16 PM
05/23/24 12:16 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
The manufacturer's will almost never admit or agree there is anything wrong or defective with their products. I order most everything in 50 to 100+ quantities. When we tell them, show them or prove to them with data what the issue/s are. I almost always get the response of "this is the first time we are hearing or seeing this". Or, "no one else is having these issues out in the field ".
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3234518
05/23/24 01:53 PM
05/23/24 01:53 PM
rickseeman
Stuttgart, Arkansas
The manufacturer's will almost never admit or agree there is anything wrong or defective with their products. I order most everything in 50 to 100+ quantities. When we tell them, show them or prove to them with data what the issue/s are. I almost always get the response of "this is the first time we are hearing or seeing this". Or, "no one else is having these issues out in the field ". Yes, maybe they should measure the spacing on their head dowel pins. Then they could see why the heads won't go on. But they probably can't drive the head dowels in because the holes are .244" at best and the dowels (not that I got any with mine) are .246"
[Re: rickseeman]
#3234520
05/23/24 02:04 PM
05/23/24 02:04 PM
ZIPPY
S.E. Michigan
Might have been too cheap to get the files from Royal Oak Boring, or maybe Royal Oak wouldn't sell the info so they just made it up as they went along?
At any rate, Sad they have good castings to work with and aren't finishing them as well as they could.
Never was 100% clear who owned the machining files before the licensing thing happened, but if the block casting is considered a licensed chrysler product then the machining specs should be also.
It's all a big mess/situation normal
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3234549
05/23/24 04:44 PM
05/23/24 04:44 PM
rickseeman
Stuttgart, Arkansas
I'm sure Mopar has prints to make a 426 Hemi.
[Re: rickseeman]
#3234644
05/24/24 08:17 AM
05/24/24 08:17 AM
ZIPPY
S.E. Michigan
Yes I'm sure they still do, but from past experience seeing them the paper prints at Mopar were almost always horrific. Without a doubt, the worst one I ever saw was the stage3 max wedge head print. It wouldn't surprise me at all if the 426 Hemi paper prints were equally awful or worse, but maybe they were redone around the time of the water+megablock and are newer. The CNC files used on the previous generation would have been the easy way to do this product. Royal Oak boring did a nice job on the previous generation, it's too bad that wasn't passed along, as it should have been. Oh well, I'm still working with stuff from 2008-2009... maybe one day I'll get to try the newer ones and will then have something to complain about
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3234661
05/24/24 10:01 AM
05/24/24 10:01 AM
JohnRR
Yes I'm sure they still do, but from past experience seeing them the paper prints at Mopar were almost always horrific. Without a doubt, the worst one I ever saw was the stage3 max wedge head print. It wouldn't surprise me at all if the 426 Hemi paper prints were equally awful or worse, but maybe they were redone around the time of the water+megablock and are newer. The CNC files used on the previous generation would have been the easy way to do this product. Royal Oak boring did a nice job on the previous generation, it's too bad that wasn't passed along, as it should have been. Oh well, I'm still working with stuff from 2008-2009... maybe one day I'll get to try the newer ones and will then have something to complain about I had to correct a bunch of stuff on my circa 2003ish 426 crate motor , angle of the lifter bores was off , deck height too tall , the bellhousing mounting surface was not perpendicular to the crank centerline and the mainline bore had a taper in all the holes , clearance was wider on one end vs. the other ????
[Re: JohnRR]
#3234676
05/24/24 10:57 AM
05/24/24 10:57 AM
ZIPPY
S.E. Michigan
Oh okay, if that's how they were, then.
I'll eventually work with one of them too, but I need to get a set of main caps for it.
We will probably have to guess whether if the specs were wrong, or if the machine work itself was garbage/qc?
Seems like from 08 to 13 they were fairly decent but that was the only timeframe that thought might apply.
Rich H.
Esse Quam Videri
