Callies Iron Hemi Block #3229341
04/26/24 04:08 PM
04/26/24 04:08 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Anybody using the Callies iron Hemi block? If so were there any problems?
Re: Callies Iron Hemi Block [Re: 71birdJ68] #3229374
04/26/24 08:26 PM
04/26/24 08:26 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Oh yeah,
Lifter holes & oil galleys are atrocious and will need much deburring
Head dowels are too close together, plan on grinding dowels to fit heads
Check threads on every hole, pipe threads will need to be tapped deeper
Grind relief in the valley where inside head nuts go for wrench clearance if it's a Hemi
#7 exhaust pushrod might need more clearance if it's a Hemi
All the .246" dowel pin holes were way too tight
Ream dowel holes to .245”
If it's a Hemi and you are going to run TTI headers, if you wait to grind for clearance on the block until you get it in the car, I'll go ahead and offer $500 for your car now. And at midnight the night you put it in you will call me to tell me to come and get it.
There might have been more, but that's all I can think of.
I did a video on Callies block prep. If you want to see it, I will look up what number it was.
2011 Drag Pak Challenger
Re: Callies Iron Hemi Block [Re: rickseeman] #3229384
04/26/24 10:26 PM
04/26/24 10:26 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Hopefully you can find a .245" reamer on ebay.
I looked through the videos for one that was specific to Callies block prep, it was a little scattered throughout the build but the lifters are the worst thing and they are in episode 5, Here's a link:
https://youtu.be/2YW0rVTbXhA
There is other Callies info in the whole build. Here is a link from the beginning:
https://youtu.be/iKkjpiraZnw
Re: Callies Iron Hemi Block [Re: rickseeman] #3229396
04/26/24 11:17 PM
04/26/24 11:17 PM
Morristown Tn.
Morristown Tn.
Its there a good alternative for a strictly street car? I need a new block.
Re: Callies Iron Hemi Block [Re: 71birdJ68] #3229398
04/27/24 12:26 AM
04/27/24 12:26 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I like them. I’m just saying this isn’t the old days. It will take a little time to get it right. Like everything else we buy today. We are building engines with all aftermarket parts. Just take your time and keep your eyes open. You might as well start from the beginning of that series and it will guide you through building a Callies Hemi. Every thing will be fine.
Re: Callies Iron Hemi Block [Re: rickseeman] #3229421
04/27/24 07:29 AM
04/27/24 07:29 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have two, and other than the lifter bores on one were not finish reamed, no issues....
Re: Callies Iron Hemi Block [Re: 71birdJ68] #3231579
05/07/24 03:17 PM
05/07/24 03:17 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I just picked up a production 1966 block and set of heads, am going to have it baked and peened first, but initially it looks like it will clean up at 0.030. was going to try and find a rotating assembly for it. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
