Re: Front steering linkage, suspension assembly help needed [Re: 73cuda340] #3231321
05/06/24 09:48 AM
05/06/24 09:48 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
What ever is wrong with the steering side a file will not fix it
Be sure the pitman arm and idler arm are the same length
With the steering centered please measure the height difference between each end of the center link. Car needs to be at ride height
Re: Front steering linkage, suspension assembly help needed [Re: ThermoQuad] #3231828
05/08/24 08:59 PM
05/08/24 08:59 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'll get a measurement hopefully in the next day or so and I've read more on the pitman arms and apparently, the manual and power are the same so I'll try putting my other one from the power box on for comparison.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Front steering linkage, suspension assembly help needed [Re: 73cuda340] #3234688
05/24/24 11:47 AM
05/24/24 11:47 AM
clarks summit pa
clarks summit pa
I measured the steering arm differences and they are only 1/8" difference from drivers side to passenger side. I also just noticed that the pitman arm now hits the header tube as well. I'm figuring at this point it has to be either the pitman arm or the pst steering box.
Re: Front steering linkage, suspension assembly help needed [Re: 73cuda340] #3234718
05/24/24 01:23 PM
05/24/24 01:23 PM
clarks summit pa
clarks summit pa
I installed a shim on each of the top steering box holes and the pitman arm and steering rod bolt both clear now, but the centerlink still isn't parallel with the ground. Is this a problem? I don't want to add a ton of shims to correct it if it won't cause any issues.
