Advice on Gasket Dressings #3231159
05/05/24 02:32 PM
05/05/24 02:32 PM
Northeast
Racer68 Offline OP
Racer68  Offline OP
Northeast
I’m about to change the gasket on my transmission’s servo (ATI) cover. It’s a paper gasket and I’m looking for some advice as to whether to put it in dry or dress it with something like aviation Form a Gasket. I asked ATI and they said they put them in dry. But I was thinking it’s a pretty new trans and it didn’t take long for it to leak. Any advice would really help.
Re: Advice on Gasket Dressings [Re: Racer68] #3231161
05/05/24 02:41 PM
05/05/24 02:41 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Nope.
Maybe a skin of silicone on a metal clad seal. A dab on pump bolt gaskets, maybe. Teflon for pipe threads and pump bolts, Other than that, dry on everything in a transmission.
Glide? Stock case? Lots of power? Someone didn't crack the case with a cooler fitting?
Re: Advice on Gasket Dressings [Re: CMcAllister] #3231180
05/05/24 03:51 PM
05/05/24 03:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Was the old gasket leaking ? Was anything on it ?
I once had a 727 that appeared to be a bit porous near the pan gasket; no gasket or prep would address the weepage.
Hopefully that's not the issue here.
Re: Advice on Gasket Dressings [Re: topside] #3231191
05/05/24 05:26 PM
05/05/24 05:26 PM
PA
moparacer Offline
moparacer  Offline
PA
Nothing on servo cover gaskets ever here. Always dry. Is it a powerglide? If so It has an oring on it for additional sealing anyways. Should never leak. Have never put so much as a dab of sealer on anything transmission related.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
