Re: Oil Filter
[Re: dragracedr]
#3230876
05/03/24 07:58 PM
05/03/24 07:58 PM
Posts: 2,524 PA
moparacer
PA
If you can get past the China part there is nothing wrong with the current Wix 51515R. I have also used the K&N HP-3001. It is Made in Mexico. Fram HP-1s are fine now too.
Thought about trying Baldwin but lack of local availability has kept me from trying one.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Oil Filter
[Re: Neil]
#3230916
05/04/24 12:29 AM
05/04/24 12:29 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
You can buy Baldwin on Amazon, they have a store. We used to use them on our construction fleet. For some reason I’ve not considered them for the old cars. Probably because Wix was all I used, it did the job, was always available at my buddies at the old Car Quest, and wasn’t made in china. I’ll give Baldwin a try when my stash runs out. I’d have zero hesitation based on previous experience.
I want my fair share
Re: Oil Filter
[Re: racerx]
#3230935
05/04/24 07:45 AM
05/04/24 07:45 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
While not a race filter I have had really good luck with the Mopar branded filters. I believe they are actually made my Purolator but I am not positive. I had a situation where I lost some rocker arm needles. The oil pump looked exactly like you would have expected from eating needles. My bearings looked excellent so the filter no doubt did its job.
68 Barracuda Formula S 340
Re: Oil Filter
[Re: racerx]
#3230938
05/04/24 08:10 AM
05/04/24 08:10 AM
Posts: 178 Suffolk,VA
dragracedr
Suffolk,VA
according to a thread on forbbodiesonly, Wix 51515 are USA-made but 51515R 's have been outsourced to China.
Re: Oil Filter
[Re: mopar dave]
#3230942
05/04/24 08:35 AM
05/04/24 08:35 AM
Bad340fish
Tulsa OK
As long as the area of the holes combined is larger than the center hole I am not sure it matters.
Re: Oil Filter
[Re: mopar dave]
#3230943
05/04/24 08:39 AM
05/04/24 08:39 AM
Posts: 1,767 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I primarily use the Moroso filter. I did try the Wix Racing once without issue, but here is something to think about. So when I was building my W2 stroker motor I had a choice of: 1) re-using the 90 deg adapter 2) using just the regular factory retaining plate (block) 3) purchasing a new aftermarket plate ...and all along, I always paid attention to the actual filter 'input flow capacity' it had, after all it does me no good to have a huge amount of oil flow from the block to the filter, if the filter itself cannot absorb all that flow. Anyways...I crafted myself a little spreadsheet calculation that gave me a quantitative picture, take a look at the attachment. Bottom line: the limit, by far, was the size of the flow through the block's oil ports, so on a SB Mopar that's the output port that feeds into the filter and the input port that feeds from the filter. BTW: I use Wix filters all around, and the field marked EXTRA in that spreadsheet reflects the additional holes I drilled in the factory plate so that the overall flow through the plate would exceed what the block openings themselves were capable of flowing.
Re: Oil Filter
[Re: mopar dave]
#3230999
05/04/24 01:44 PM
05/04/24 01:44 PM
Diplomat360
Windsor, ON, Canada
I agree, but why would Moroso put so many large holes in their filter? Perhaps intended for non-OEM installations where the passages have been enlarged and a non-factory filter install is used...maybe like a remote filter install???
Re: Oil Filter
[Re: Bad340fish]
#3231029
05/04/24 04:03 PM
05/04/24 04:03 PM
Posts: 11,686 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As long as the area of the holes combined is larger than the center hole I am not sure it matters. More like as long as the ring of holes flow more than the filter area that they are feeding. The filter element should be the restriction, not any holes. Use a low restriction/higher micron rated element, and the flow requirement goes way up. Filters made in PRC is a deal breaker for me. Quality control is out the window. Don't make the mistake of thinking the company putting their name on the stuff has control of that.
Re: Oil Filter
[Re: Bad340fish]
#3231070
05/04/24 08:54 PM
05/04/24 08:54 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
You can always use Mopar 05037836AA, it's the Viper filter, 3/4-16, high pressure rated, and short enough to not touch the belts on BB with the lower idler pulley. I think I pay 18.00 Canadian for these at the dealer.
Re: Oil Filter
[Re: Uberpube]
#3231089
05/05/24 06:57 AM
05/05/24 06:57 AM
dragracedr
Suffolk,VA
You can always use Mopar 05037836AA, it's the Viper filter, 3/4-16, high pressure rated, and short enough to not touch the belts on BB with the lower idler pulley. I think I pay 18.00 Canadian for these at the dealer. thanks. I'll look into that filter. I have a 51515R on the car now and 2 more on the shelf. I'm a bit leery about continuing to use them.
Re: Oil Filter
[Re: dragracedr]
#3231106
05/05/24 10:02 AM
05/05/24 10:02 AM
Posts: 34,943 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have a case of each from at least 5 years ago ..
Baldwin has a factory about 35 miles from me in Yankton,sd
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Oil Filter
[Re: dragracedr]
#3231108
05/05/24 10:08 AM
05/05/24 10:08 AM
Posts: 2,524 PA
moparacer
PA
You can always use Mopar 05037836AA, it's the Viper filter, 3/4-16, high pressure rated, and short enough to not touch the belts on BB with the lower idler pulley. I think I pay 18.00 Canadian for these at the dealer. thanks. I'll look into that filter. I have a 51515R on the car now and 2 more on the shelf. I'm a bit leery about continuing to use them. Has there been any documentation of a decline in quality with the 51515R? I have continued to use them since this China flap started and have cut several apart and I see no difference in quality or performance from the one's I have used.
