Front steering linkage, suspension assembly help needed
#3230675
05/02/24 05:03 PM
05/02/24 05:03 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I need help with some clearance issues that I'm having on my cuda. I just finished installing all new hotchkis adjustable upper a arms, adjustable strut rods and steering rods, qa1 lower control arms, firm feel 1.06 torsion bars, pst manual steering box, and moog pitman arm. The centerlink and idler arm the same ones that I had on the car originally and the k member is original, but it was sent to al debevec for a factory hemi mount conversion. The centerlink is not sitting level and is higher on the drivers side, the heim joint on the steering rod on the drivers side is barely clearing the torsion bar and with any movement, it will most likely hit it and the drivers side tire hits the upper control arm when turned all of the way. The centerlink also hits the oil pan on the passenger side withbthe steeringvwheel turned. I'm not sure where to even start to fix this since just about everything is new. The steering rods were adjusted to the same length as the originals. The car isn't aligned yet, and with everything just bolted on I expected a few issues but nothing like this. I'm not sure if its the new pitman arm or if the idler arm and spacers are installed correctly or not. I'll post a few pictures to show what it looks like.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Front steering linkage, suspension assembly help needed
[Re: 73cuda340]
#3230677
05/02/24 05:06 PM
05/02/24 05:06 PM
73cuda340
clarks summit pa
[Re: 73cuda340]
#3230681
05/02/24 05:12 PM
05/02/24 05:12 PM
73cuda340
clarks summit pa
The lower ball joints were also changed and the front tires are 245/60/15s so there not crazy wide to where the would hit the upper a arms.
[Re: 73cuda340]
#3230709
05/02/24 08:27 PM
05/02/24 08:27 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
Anyone else have a problem with how this brake line is routed?
[Re: GomangoCuda]
#3230711
05/02/24 08:41 PM
05/02/24 08:41 PM
Posts: 5,931 ohio
ruderunner
ohio
Yes. And why would the bumpstop go into a void?
As for the center link, disregard the oil pan for now. Are the link ends parallel to the torsion bar centers?
The steering box can be shimmed or the idler can be egged to correct the discrepancy.
But, do you have an E body K to begin with? 66 to 70 B are very similar but IIRC mount the box at a slightly different angle.
Angry white pureblood male
[Re: GomangoCuda]
#3230760
05/03/24 07:58 AM
05/03/24 07:58 AM
73cuda340
clarks summit pa
Anyone else have a problem with how this brake line is routed? I bought a new front brake kit so the brake lines and calipers are coming back off. They're just installed for now until I can get the steering and alignment finished and the brakes are being swapped out. I asked the guy that did the conversion if it's the same k member that I sent him and he insists that he sent back the same one. I questioned this as soon as I got it back.
[Re: TC@HP2]
#3230780
05/03/24 09:27 AM
05/03/24 09:27 AM
73cuda340
clarks summit pa
Ok, I'm just wondering if it's something with the new parts because everything fit together perfectly with the original parts and it's still the same centerlink and idler arm
[Re: TC@HP2]
#3231071
05/04/24 08:59 PM
05/04/24 08:59 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Sounds like a problem on the driver's side. Do you have the original steering box and pitman arm to compare?
[Re: Magnum]
#3231072
05/04/24 09:11 PM
05/04/24 09:11 PM
73cuda340
clarks summit pa
I have the original steering box and pitman arm but I swapped from power to manual steering. Are the pitman arms the same between power and manual? I've read that they are and they aren't.
[Re: 73cuda340]
#3231084
05/05/24 12:06 AM
05/05/24 12:06 AM
Posts: 10,232 Someplace you aren't
SomeCarGuy
The center link will hit the pan when the steering wheel isn’t centered when the tie rods are set. I don’t think it’s as big a deal with a stock pan, but a milodon takes up more space and you encounter this.
I’m wanting to say the pitman is the same for both boxes, but it’s been years so don’t quote me.
I want my fair share
[Re: 73cuda340]
#3231138
05/05/24 12:37 PM
05/05/24 12:37 PM
Posts: 6,317 nowhere
Sniper
nowhere
I have the original steering box and pitman arm but I swapped from power to manual steering. There is no way you could have the original steering box AND swap from power to manual steering. As for the pitman arm size, depends on the year of the manual box. Early ones used a different size pitman arm, later ones same as power boxes. Not sure about truck boxes though.
[Re: Sniper]
#3231141
05/05/24 12:44 PM
05/05/24 12:44 PM
73cuda340
clarks summit pa
I meant I can't compare them side by side. The car was originally power steering and I swapped in a new manual steering box
[Re: Sniper]
#3231189
05/05/24 05:23 PM
05/05/24 05:23 PM
73cuda340
clarks summit pa
Both boxes that I have are the large sector, I just didn't know if the geometry or length was different between the power and manual
