Re: Should I put it on???? Thermostat housing
[Re: yellow sixpack]
#323036
05/19/09 07:24 PM
05/19/09 07:24 PM
Posts: 11 California, USA
allblknblue
California, USA
Honestly, if you can, go with a CSR. I've had two chrome water necks and both warped A TON with barely any torque on the bolts. I have a brand new WP housing, gasket, and silicone and I still get a little bit of a leak. If you can't afford a CSR, just try a billet neck with an o-ring.
The excitement is in the curves.
#323037
05/19/09 07:51 PM
05/19/09 07:51 PM
RapidRobert
draw file it to take the chrome off & use it, it might work Ok & save from purchasing another one but DO keep an eye on it.
[Re: 318 Stroker]
#323042
05/20/09 05:41 AM
05/20/09 05:41 AM
Posts: 1,012 indiana
mcmopars
indiana
Take it to the lake, and chuck it as far as you can...
best said.i got the aluminum one from mancini,nice piece
#323045
05/20/09 07:34 AM
05/20/09 07:34 AM
Posts: 4,799 ILL
MLR426
ILL
I surface all the thermostat housings before installing NEW and Used for a flat surface or removing the plating from the housing for a good seal. You can also do this on a flat surface with a piece of 60 or 80 grit sand paper and lap or sand the surface flat.
logan426
[Re: MIRADAMANia]
#323049
05/20/09 11:13 AM
05/20/09 11:13 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
My chrome Mr gasket dosent leak.Just a gasket and a bit of Permatex sealer.Been on for 7 years.Rocky
Chrysler Firepower
[Re: MIRADAMANia]
#323050
05/20/09 11:31 AM
05/20/09 11:31 AM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
My chrome one was leaking and corroded badly so I got a stock cast iron from the parts store but the bolt holes are too small and too close together to fit on my Edelbrock alum. manifold. It's a 318. Anybody know what will fit?
I have a 318 with an Eddy manifold. The factory original cast housing fits perfectly...
