1970 satelite column shift lever vs. 68 RR #323013
05/19/09 06:52 PM
05/19/09 06:52 PM
Minnesota
70dartswinger Offline OP
Minnesota
My brother needs a column shift lever arm for a 68 Roadrunner. I have a column shift arm for a 70 Belvedere. Are they the same part?
Re: 1970 satelite column shift lever vs. 68 RR [Re: 70dartswinger] #323014
05/19/09 11:44 PM
05/19/09 11:44 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
They are slightly different. The 70 shifter levers are bent at a sharper angle and most were satin chrome plated. The 68-69 B-body column shift levers have less of a bend and were shiny chrome plated. You could probably swap them if you absolutely need to have a shifter lever to move the car around, but otherwise I would keep a look out for a 68 or 69 shifter lever.
Re: 1970 satelite column shift lever vs. 68 RR [Re: 70dartswinger] #323015
05/20/09 08:06 AM
05/20/09 08:06 AM
Minnesota
Minnesota
