98 Dakota automatic transmission overdrive wiring bypass?
#3229814
04/28/24 07:44 PM
04/28/24 07:44 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Hi, a friend of mine has a 98 Dakota with an automatic. The overdrive is not working and he wants to bypass The ECU on it and just use a toggle switch like I did on my '93. I have heard that the wiring is different on trucks newer than 93 so I can't tell him how it works. Does anybody have a wiring diagram or instructions on how to do it with the '98 models? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: 98 Dakota automatic transmission overdrive wiring bypass?
[Re: JDMopar]
#3229830
04/28/24 08:46 PM
04/28/24 08:46 PM
Hemi_Joel
Minnesota
I assumed it was a 318, but I'll have to ask him.
[Re: A990]
#3229869
04/29/24 01:40 AM
04/29/24 01:40 AM
Hemi_Joel
Minnesota
[Re: JDMopar]
#3229913
04/29/24 10:08 AM
04/29/24 10:08 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
Not sure if that can be done on an OD newer than 95? All of the newer ones are controlled by the TCM in the computers. What engine is in his Dakota? If it's a 4.7, it is an entirely different transmission than a 518 or 46RH in the older trucks. I'm not sure when they stopped the 5.2 & 5.9 Magnums in Dakotas and Durangos, but those would have had a 42RE or a 46RE in them. The 4.7 vehicles had a 545RFE. Maybe some of the guys on here who know and work on transmissions will chime in. OD is still controlled by a solenoid so controlling it with a toggle switch shouldn't be an issue. Same with lockup, the diesel guys have been controlling the Lockup with a switch on the RE's forever ... All he has to do is switch ground .
[Re: BDW]
#3229952
04/29/24 12:18 PM
04/29/24 12:18 PM
JohnRR
I always read the RE has a digital code needed, not just grounding the pins like the RH? Would have gotten a RE if that were the case instead of the 518 when I did the swap. I know there are controllers for the RE available. I'm looking at the pages provided above and it doesn't look that way for OD and lockup anyway ?? The RE needs digital for the gov pressure circuit , on my 2000 ram I put a resistor on the line to the PCM (BCM?) to fool the gov pressure circuit to not see the increased pressures , that worked perfect for over 200K miles ...
[Re: JohnRR]
#3230274
04/30/24 04:19 PM
04/30/24 04:19 PM
Posts: 3,904 Oregon
hooziewhatsit
Correct. On the RE, the computer controls the governor pressure (trying to get ~1psi/mph, then the valves in the transmission control shift points off of that). Lockup & OD are still solenoids that can be triggered externally. Computer may not like it though
[Re: Hemi_Joel]
#3230287
04/30/24 04:54 PM
04/30/24 04:54 PM
Posts: 3,093 Michigan
A727Tflite
Thanks for the help. With this being a '98, would it have the RE, with the computer control of more than just the lock-up and OD? Round black connector in the case = RE. White oval connector in the case = RH. (The hole in the case is round but the connector top is oval).
[Re: merpar]
#3230306
04/30/24 06:05 PM
04/30/24 06:05 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
The RE has a 3 prong connecter the RH has a 2 prong connecter
RE has LOTS of wires, RH has 3 ,, center one is + one outer is lock up, the other outer is OD
[Re: Hemi_Joel]
#3230424
05/01/24 09:25 AM
05/01/24 09:25 AM
JohnRR
Thanks for the help. With this being a '98, would it have the RE, with the computer control of more than just the lock-up and OD? 98 should be RE , they started either 95 or 96 ...
[Re: JohnRR]
#3231049
05/04/24 05:10 PM
05/04/24 05:10 PM
Hemi_Joel
Minnesota
He brought the truck over today and I went under and looked at it. He said the engine is a 318, but the original transmission was bad and one was swapped in out of a 93 he thinks. Also the wires are bare, as you can see in the picture, and they were touching. So I separated them out. So one of these gets grounded to activate the overdrive, right? The brown green one? Or does it get 12 volt positive supplied to it? And then apparently the black one activates the lockup converter. If it's really a 93 transmission, does it even have lockup capability? Thanks a lot, Joel
