What needed to swap from a spool to a suregrip in a Dana 60? #3228853
04/23/24 10:50 PM
04/23/24 10:50 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I lucked out this past weekend when I went to the Spring Fling CPW show and while buying a pile of housing for a friend, I seen someone had a Dana 60 for sale. I asked him what was up with it. Was told it was set up for a race car, 1971 b-body perches, spool with 4:56, moser axles and 10in brakes. After forking over $1000 for it, I needed to convert it to a suregrip for street/strip use and plan to use 3:23/3:55 ratio ring and pinion. Was just going to order everything from Cass (Dr Diff) and have a local shop do the work. I am tempted to use the helicoil sure grip he offers, but am open to suggestions. As of now, do not know if it has 30 or 35 spline axles? What WILL NEED REPLACING?
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: migsBIG] #3228895
04/24/24 09:48 AM
04/24/24 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Since you want to do a gear change , no 3.23 for the dana 60 , 3.54 is the lowest you will find NEW in the aftermarket ... Spool , gears and bearings , out with the old , in with the new . as long as the helical unit is from Cass and not an eaton true, track , the one I used in a friends 8.8 was put together wrong by eaton and chewed it self up in 15k miles.
Danas are either 35 spline or 23 spline , if that is a 71 and has stock axles , scary wit ha spool and 4.56's , it would be 35 spline. I'm unsure if the aftermarket spools are 30 spline for the dana 60 , pull an axle and find out what you have.
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: JohnRR] #3228901
04/24/24 10:17 AM
04/24/24 10:17 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Get a hold of Dr Diff.
STOP POTATO HATE!
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: migsBIG] #3228949
04/24/24 01:37 PM
04/24/24 01:37 PM
I may have a good used early 3 series Dana corp. clutch type, not an Eaton, posi unit that I'm never going to use now.
PM me on here if your interested in buying it.
Thanks: Cab
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: Cab_Burge] #3229157
04/25/24 04:21 PM
04/25/24 04:21 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: migsBIG] #3229181
04/25/24 05:26 PM
04/25/24 05:26 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
If it has Moser axles you have to ask if they are compatible with stock Dana splines. Even if the amount of splines is the same, that doesn't mean they are compatible. Ask before you spend money.
2011 Drag Pak Challenger
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: rickseeman] #3229199
04/25/24 08:12 PM
04/25/24 08:12 PM
Bakersfield Ca
jmoparman Offline
jmoparman  Offline
Bakersfield Ca
Was told it’s 35 spline
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: jmoparman] #3229280
04/26/24 09:31 AM
04/26/24 09:31 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Correct length axels, imo I would use tapered bearings on axel, I don’t trust the side load strength on the green bearing for street
Re: What needed to swap from a spool to a suregrip in a Dana 60? [Re: Mr PotatoHead] #3229290
04/26/24 10:15 AM
04/26/24 10:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
well looky there , 3.23 for a dana 60
