Re: Does anyone make a fuel sender that works?? [Re: TJP] #3229118
04/25/24 12:26 PM
04/25/24 12:26 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Originally Posted by TJP
[quote=ruderunner]Theory on why senders read full during a dry test vs actual use.
We're adjusting the senders and assuming the float will reach the top of the tank.
We're forgetting about air space above the fuel and the fact that the float won't touch the top of the tank in operation.
If someone is in this process, try setting the float for an inch gap from the top of the tank.
Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ?
Whether the neck is full or not, there's still going to be air pockets in the tank. Even the vent lines aren't completely against the top of the tank.
Either way, the test is simple enough to try.
Angry white pureblood male
Re: Does anyone make a fuel sender that works?? [Re: moparx] #3229120
04/25/24 12:51 PM
04/25/24 12:51 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted by moparx
"Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ?"
i have screwed up filling up my charger till the fuel ran all over the quarter, and out the vent line [which dumps into the frame rail] making a real mess. panic laugh2
i don't think there was any air that time. [sure stayed on full for long time.]
however, that was tons of years ago, and i'm super careful these days filling it up.
also, the mess was during the time i had the original tank and sender in it.
beer
I've had nothing but problems filling older cars with gas and the spill over. I don't know if it's in the design of newer pump nozzles or what, but now I put my ear down and listen for it getting full and stop manually.
Facts are stubborn things.
Re: Does anyone make a fuel sender that works?? [Re: larrymopar360] #3229148
04/25/24 03:45 PM
04/25/24 03:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's the curse of the A-bodies - learned long ago to listen to the rising tide of gas...
Re: Does anyone make a fuel sender that works?? [Re: wingman] #3229225
04/25/24 09:49 PM
04/25/24 09:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by wingman
Has anyone had success using a device like this inline to compensate for their incorrect aftermarket sender/factory gauge? I've heard from some that they work, and others that they do not.
Basically an adjustable resistor I assume?
https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=748/mode=prod/prd748.htm
they do work if you're fairly close (within 1/4 tank). I've installed quite a few as it sure beats filling, emptying, tweaking the float arm and repeating with no gain.
A bit of a PITA due the wiring etc. but less so than the mentioned circle jerk twocents up beer
