Does anyone make a fuel sender that works??
#3227939
04/18/24 05:19 PM
04/18/24 05:19 PM
Posts: 2,523 God's Country Maryland
GODSCOUNTRY340
I bought a sender last year at Carlisle that was claimed to be compatible with Mopar ohm range (69 'Cuda). Well, they were full of S-it. With an empty tank (new tank) it reads 3/4 tank. I bought one of those gas tank sender adjusting modules from Speedway and it won't work correctly either. On top of that the gasket for the sender leaks and the new grommet for the filler tube leaks. Are all these companies that incompetent? So, now my question, who makes the correct sender for Mopar gas gauges? I've heard the ohm range is between 10 & 73, is this correct? Thanx for any help.
Re: Does anyone make a fuel sender that works??
[Re: GODSCOUNTRY340]
#3228037
04/19/24 11:00 AM
04/19/24 11:00 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
I bought a sender last year at Carlisle that was claimed to be compatible with Mopar ohm range (69 'Cuda). Well, they were full of S-it. With an empty tank (new tank) it reads 3/4 tank. I bought one of those gas tank sender adjusting modules from Speedway and it won't work correctly either. On top of that the gasket for the sender leaks and the new grommet for the filler tube leaks. Are all these companies that incompetent? So, now my question, who makes the correct sender for Mopar gas gauges? I've heard the ohm range is between 10 & 73, is this correct? Thanx for any help. The short answer is to seek out an NOS MOPAR sender and pony up with whatever the seller wants if you want a gauge that works correctly.
[Re: 70sixpkrt]
#3228065
04/19/24 12:05 PM
04/19/24 12:05 PM
GODSCOUNTRY340
You might want to call Kramer Auto. I bought might from them about 5 years ago and still reads good. At that time, they recalibrated and made sure it worked before shipping it out. You have to call them because some of the sending units are not listed. http://www.kramerauto.com I've dealt with Jim Kramer many times, I actually bought my 'Cuda from him. He's a great guy and honest, but it seems a little hard to get in touch with him lately.
[Re: 70sixpkrt]
#3228351
04/20/24 11:04 PM
04/20/24 11:04 PM
JohnRR
U.S.S.A.
You might want to call Kramer Auto. I bought might from them about 5 years ago and still reads good. At that time, they recalibrated and made sure it worked before shipping it out. You have to call them because some of the sending units are not listed. http://www.kramerauto.com I didn't know they did that .
[Re: JohnRR]
#3228556
04/22/24 09:09 AM
04/22/24 09:09 AM
Posts: 9,856 MI, usa
dvw
MI, usa
I'm pretty decent at electricical. I've had this same issue on my wifes 67 jeep Gladiator. New sender ( 2 different styles) read correctly out of the tank when hooked up to the truck harness. It appears to read correctly when installed disconnected from the truck harness and checked with an ohmeter. I have an adjustable resitance box. When I connect that to the harness at the tank, the factory gauge the gauge reads correctly. I ran new wiring from the sender by passing the cluster connection directly to the gauge. The result? it reads 3/4 at full, still has plenty of fuel on E. Doesn't make any sence to me. Doug
[Re: dvw]
#3228748
04/23/24 12:01 PM
04/23/24 12:01 PM
Posts: 19,480 north of coder
moparx
I'm pretty decent at electricical. I've had this same issue on my wifes 67 jeep Gladiator. New sender ( 2 different styles) read correctly out of the tank when hooked up to the truck harness. It appears to read correctly when installed disconnected from the truck harness and checked with an ohmeter. I have an adjustable resitance box. When I connect that to the harness at the tank, the factory gauge the gauge reads correctly. I ran new wiring from the sender by passing the cluster connection directly to the gauge. The result? it reads 3/4 at full, still has plenty of fuel on E. Doesn't make any sence to me. Doug same thing happened to me when i installed a new stainless sender/pickup in the replacement tank i installed in my charger. i checked the resistance of the sender before installation, and it was spot on. just to insure it had a good ground for the sending unit, i soldered another wire from the sender case to the pickup tube inside the tank, then soldered another wire to the outside pickup tube, to ground to the body sheet metal in a newly drilled hole. however, once installed it reads all over the place. i have never seen F, and a couple of times when it said E, it only took 5 gallons to fill the tank ! the original, super rusty sending unit read almost 3/4 of a tank when it was replaced, and i drained out almost 15 gallons of "weed killer" from the original tank.
[Re: moparx]
#3228758
04/23/24 12:29 PM
04/23/24 12:29 PM
JohnRR
U.S.S.A.
Has anyone tried swapping the float resistor from an original one into one of the replacements ?
[Re: TJP]
#3228863
04/23/24 11:40 PM
04/23/24 11:40 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Mine reads about like what is described here. 3/4 on gauge when full. Empty means you have like half a tank. Has anyone tried bending the arm to compensate? This sender was in the car when I got it, no idea where it came from. I’m guessing this car was gone through in the 00s.
My last car was pretty good, read 7/8 when full, empty was empty. It seems to have been rebuilt in the 90s
I want my fair share
[Re: TJP]
#3228913
04/24/24 11:24 AM
04/24/24 11:24 AM
moparx
Has anyone tried swapping the float resistor from an original one into one of the replacements ? Not easily done as the resistor board / connections are riveted and the wire is quite fragile. Good thought though. plus, the float resistor is spot welded to the pickup tube. [at least mine is.] you would have to be extremely careful removing the float resistor from the new assembly, then you could silver solder the original float resistor to the stainless pickup tube. and being a charger with the big side hole the filler tube goes in, i installed the sender when the tank was out and lifted and lowered the float arm while checking the resistance. [this checked out almost spot on at full and empty, and the dash gauge read real close to what it should at full and empty.] i figured everything was good to go, but when the tank was installed, the dash gauge ain't even close in operation, although a couple of times it did read full when the tank is full. yes, the tank and sender are both grounded well, with multiple ground attachments. i'm wondering if the float [which is brass] is no good. however, that would not explain why the dash gauge reads full, occasionally. it is rather irritating to be sure !
[Re: JohnRR]
#3228924
04/24/24 12:21 PM
04/24/24 12:21 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I bought a sender last year at Carlisle that was claimed to be compatible with Mopar ohm range (69 'Cuda). Well, they were full of S-it. With an empty tank (new tank) it reads 3/4 tank. I bought one of those gas tank sender adjusting modules from Speedway and it won't work correctly either. On top of that the gasket for the sender leaks and the new grommet for the filler tube leaks. Are all these companies that incompetent? So, now my question, who makes the correct sender for Mopar gas gauges? I've heard the ohm range is between 10 & 73, is this correct? Thanx for any help. The short answer is to seek out an NOS MOPAR sender and pony up with whatever the seller wants if you want a gauge that works correctly. Bingo. This has been my experience as well.
Facts are stubborn things.
[Re: SomeCarGuy]
#3228926
04/24/24 12:23 PM
04/24/24 12:23 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My last car was pretty good, read 7/8 when full, empty was empty. It seems to have been rebuilt in the 90s Yep this is what I normally experienced with Spectra or whatever brand other than Mopar. I never pushed it when it showed empty but I knew there was several gallons left.
[Re: larrymopar360]
#3228982
04/24/24 05:46 PM
04/24/24 05:46 PM
Posts: 5,886 ohio
ruderunner
ohio
Theory on why senders read full during a dry test vs actual use.
We're adjusting the senders and assuming the float will reach the top of the tank.
We're forgetting about air space above the fuel and the fact that the float won't touch the top of the tank in operation.
If someone is in this process, try setting the float for an inch gap from the top of the tank.
Angry white pureblood male
[Re: ruderunner]
#3229038
04/24/24 11:33 PM
04/24/24 11:33 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
If someone is in this process, try setting the float for an inch gap from the top of the tank. Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ? I'll refer to my earlier post #3227987 for my thoughts I'm beginning to think it may have something to do with the buoyancy of the float, possibly coupled with today's fuels or weight of the arm
[Re: TJP]
#3229114
04/25/24 11:44 AM
04/25/24 11:44 AM
moparx
"Why do you believe there is air space at the top of the tank? IF the filler neck on say a 68-70 Charger is full of fuel, how could there be an air space ?" i have screwed up filling up my charger till the fuel ran all over the quarter, and out the vent line [which dumps into the frame rail] making a real mess. i don't think there was any air that time. [sure stayed on full for long time.] however, that was tons of years ago, and i'm super careful these days filling it up. also, the mess was during the time i had the original tank and sender in it.
